Author Topic: Mamewah nag screens removal  (Read 2228 times)
vettetek
  • Last login:October 05, 2025, 10:53:53 pm
« on: September 12, 2004, 10:01:43 am »
Ok,
Heres probably a easy one for you guys. I cant seem to locate the option to turn all the nags off in the NEW mamewah. It still has the "type ok" and load screens.
Im sure its a simple one that someone can set me straight on right away.
Also, Im having a problem getting a layover to appear correctly. Im using the "arcadia" one that has the background of an arcade machine and the marquees and screenshots appear in the appropriate locations. I can see the screenshots and marquees, and they DO change with game selection, and the layout is correct, but I cant seem to get the picture of the arcade game to appear! Im sure its a problem in my layover configuration, or location of the image files.
Any help would be appreciated.
Thanks,
~V
Demon-Seed
    • DemonCade (WORKING URL!)
Re:Mamewah nag screens removal
« Reply #1 on: September 12, 2004, 11:11:41 am »
Hey
In the mame.ini  under EXECUTION SETTINGS---> DEFAULT OPTIONS just type the mame commands..
 -skip_disclaimer -skip_gameinfo
That gets ride of most.. once in awhile if a game has a problem it still has OK not sure how to get ride of that.
JIM
pointdablame
« Reply #2 on: September 12, 2004, 12:13:27 pm »
read layout.txt in the /docs folder.  There is a new naming structure for layouts.  Your background image has to be emuname.xxx now
first off your and idiot
vettetek
« Reply #3 on: September 12, 2004, 11:50:18 pm »
ok,
I cant find my mame.ini...I am using mamepp...if that makes any diffrence, and as far as the layout.txt file...man! that reads like stereo instructions! :o Im not quite sure what to rename my background file...would it be mame.png?
thanks,
~V
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #4 on: September 13, 2004, 12:00:34 am »
run mame with the -cc parameter to generate the ini file.
But the one he is refering to as I now see is in your mamewah folder, than the INI folder. Thats if your using the new version.
« Last Edit: September 13, 2004, 12:01:22 am by DaemonCollector »
