Author Topic: IPAC and volcano button LEDs?  (Read 1079 times)
maraxle
« on: September 09, 2004, 04:10:38 pm »
Does anyone have any info on using an Ultimarc IPAC with the old Atari volcano buttons?  If I wanted to do that, am I going to need the LED harness that Ultimarc sells?  Also, I don't know what the voltage is on those volcano buttons.  Will I need a resistor in there to make it work with it?  Any help would be much appreciated.
Thanks in advance!
Tiger-Heli
    • Tiger-Heli
Re:IPAC and volcano button LEDs?
« Reply #1 on: September 09, 2004, 04:21:44 pm »
Thanks in advance!
Search the board on Volcano.  Pretty sure OSCAR had some good info.  As I recall, those are acutally incandescent bulbs, and a straight I-PAC won't work with it.  You could maybe use some type of driver circuit or you could convert the volcano's to 5V leds (or 2.1V LEDs with a resistor).
maraxle
« Reply #2 on: September 09, 2004, 05:09:28 pm »
From all the threads, it sounds like the volcano buttons have LEDs in them.
What size resistor will I need to be able to use the IPAC with them?  Alternatively, what are the voltage and current ratings on the LEDs?  I don't have them in hand yet so I can't look and see if they're marked.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: September 09, 2004, 05:47:52 pm »
There's a couple threads here that covered it... but there seems to be a little bit of a disagreement on the exact resistor to use. I think 330 is what you should be using.
I will be doing the same as you, but have not yet done it. All I know is after researching it, I settled on 330. But who knows if I'm making a mistake........
Ray B.
NO MORE!!
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #4 on: September 09, 2004, 06:43:37 pm »
I have done this.  You need to take the +5V from the i-pac and run it through a 330 resistor to the switch.
There is a thread about it here, where OSCAR schools me on how to make it work.
« Last Edit: September 09, 2004, 06:46:58 pm by MinerAl »
