Author Topic: Anyone running an ABIT VH6-II MB and an ArcadeVGA card (9200 chipset)?  (Read 1090 times)
exibar
  • Last login:January 02, 2025, 11:38:59 pm
  • I'm the creator of Exibar's Lair!
Is there anyone running an ABIT VH6-II socket 370 Motherboard (800 Mhz Intel CPU, 80 Gig Maxtor drive, 512Meg PC100 memory, 3-Com ethernet card, XP pro) and an ArcadeVGA card (9200 chipset)?  If so have you encountered any issues with that setup?  I'm using a WG K7000 series low res monitor too, with Andy's breakout cable (ultimarc's)
  In order to get my AVGA to produce a signal to the monitor (or even to a VGA monitor) I have to turn on the MB, then shut it off and turn it back on realy quick.  Then and only then do I get signal and everything works fine after that...
  Andy has allowed my to return this one and get another AVGA card, but if it is the MB AVGA card combo.... ugh... I don't even want to think about having to ask my wife for more $$$$ for another MB....
  Seeking someone with an identical MB an AVGA card....
  thanks all!
    Mike B
