Author Topic: Some Kind soul email me this plz  (Read 2238 times)
vader
  • Last login:January 19, 2025, 08:25:22 pm
  • I can't breathe in this thing !!
« on: September 05, 2004, 01:36:56 am »
Had a problem getting the IPAC 4 to program....fixed that problem with the latest update from Andy.  Shift problem still exist.  Can someone please email the default config file for the IPAC4.....Greatly appreciated..
vader88@bellsouth.net
Thanks Tim
vader
Re:Some Kind soul email me this plz
« Reply #1 on: September 05, 2004, 11:01:54 pm »
Hmmm.... I guess of the 85 people that built this must have keyboard hacks and no IPACS, strange indeed  :P, emailed Andy, I'm sure he will send me the correct file
tep0583
  • Last login:October 26, 2009, 05:00:51 pm
« Reply #2 on: September 05, 2004, 11:06:52 pm »
1 keyboard hack, 1 Keywiz.
I guess I could email you the Keywiz software, but I doubt it'd do what you're looking for....
Sasquatch!
  • Last login:March 01, 2010, 04:11:47 pm
  • Toot-Toot!
    • Arcade Paradise
« Reply #3 on: September 06, 2004, 12:03:45 am »
Hagstrom user here.  Sorry.
vader
« Reply #4 on: September 06, 2004, 01:28:41 am »
Well, at least you two replied...although not much help...lmao....thanks anyway
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
« Reply #5 on: September 06, 2004, 02:00:35 am »
Didn't the IPAC4 come with a CD with the original CFG stuff on it?
Seems like it would be much quicker to get this stuff direct from Andy instead of waiting for someone here.
vader
« Reply #6 on: September 06, 2004, 02:09:51 am »
First thing I did was try the CD, but no luck.  I thought I would try here first because I know Andy is a busy person and thought it would be easier to ask someone who might be browsing the boards, either way, I emailed Andy, it's not something major so it can wait.
Tim
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
« Reply #7 on: September 06, 2004, 02:53:04 am »
Can't you just go to the text-based programming tool and reset it to its defaults?  You need a PS2 keyboard attached to the I-Pac I believe.  With the jumper set to "Alt," open up a text editing program (Notepad works fine) and hit [Ctrl]+[Alt]+P.   One of the choices will be to "reset to default configuration."  Of course, this is for the older ones that have a jumper.  :)  Not sure how the newer jumperless ones I've heard about would work.
I'm not near my Ultimarc disk now, but I can't imagine that the Windows GUI Interactive Programming thing doesn't have an option to set the thing back to default as well.
If you can't be a good example at least try to be a horrible reminder.
vader
« Reply #8 on: September 06, 2004, 11:55:49 am »
The program does say set to default and I did that, but my shift key funcitonality is not coming back and I'm not exactly familiar with how to do the dos based programming
Tim
jerschwab
  • Last login:May 28, 2011, 11:44:27 am
  • I think my project will be done soon... ???
    • Free Bertuzzi!
« Reply #9 on: September 07, 2004, 03:28:00 am »
Tim
I don't know what it is exactly that you are looking for because I only have the CD... I haven't actually installed my IPAC yet.
What you could do if it is WinIPAC you are having problems with is delete the following files:
WINIPAC.IPC
WINIPAC.INI
WINIPAC.CFG
The next time you run WinIPAC, it will recreate them with the default setting.  You will want to back up your files first though.
I'm not sure if this helps, like I said I haven't actually played with my IPAC yet.
Good luck with this!
« Last Edit: September 07, 2004, 03:29:24 am by jerschwab »
maraxle
« Reply #10 on: September 07, 2004, 07:08:07 am »
Just a tip - you'd probably have gotten an answer earlier if you had given your post a more descriptive title.  For example, if you had called it "Need default config for IPAC4" I would have known not to look at this thread since I don't have an IPAC4 and am therefore of no use to you.  On the other hand, someone who owns an IPAC4 would probably have been more likely to click on it, knowing that they could possibly help you.
vader
« Reply #11 on: September 07, 2004, 07:35:52 am »
Guess I should have been more descriptive in my post and I apologize for than.  Andy emailed me back and told me to do the same thing as  jerschwab suggested, but it still is not working.  What confused me is that I can still escape by pressing the 1 and 2 player start buttons, just no enter, tab, or pausing working.
dag2000
  • Last login:May 21, 2020, 12:27:05 pm
  • One piece at a time.
« Reply #12 on: September 09, 2004, 04:45:10 pm »
