Author Topic: Out of range on certain game  (Read 1100 times)
danyboy
  • Last login:September 04, 2004, 11:36:01 pm
  • DBB
« on: September 04, 2004, 02:39:41 pm »
Hi....
I have a pc monitor on my cabinet, plugged on a 3d proghet gts pro
nvidia chipset, and i ran a lot of game but i have problem with a couples of them.
After burner
After burner 2
Outrun
I got a blank screen with a message from the monitor saying...
OUT OF RANGE
I  saw somewhere, maybe here, to put down the 3d acceleration until
it run, so i did it, but the game is ugly, like it's in 8 colors.
I'm running Windows XP, using Mamewah, but it's the same thing if i start mame from the command prompt.
Any advice on this problem...?
tyia
Dany
StephenH
Re:Out of range on certain game
« Reply #1 on: September 04, 2004, 03:00:02 pm »
Try setting your games properties to a resolution your monitor can understand.  For example, you mentioned you have a PC monitor, so if you are using command mame, I would try adding commands like to the MAME command line:
-400x300
-512x384
-640x480
-800x600
-1024x768
Till you find one that works
If you are using MAME32, then oen the properties for those games, and set the resolution accordingly.
danyboy
  • DBB
« Reply #2 on: September 04, 2004, 03:20:49 pm »
Ok, but like i said, i'm using Mamewah,
so is it possible to do this in Mamewah?
(having a command line just for specific games?)
But i'll try your tip tonight....
Dany
« Last Edit: September 04, 2004, 04:25:10 pm by danyboy »
