Author Topic: ATI Dongle question  (Read 1580 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
ATI Dongle question
« on: September 02, 2004, 05:15:34 pm »
Hello, I read the entire thread about using the ATI dongle with a component TV.  One question that I could not find an answer to, which dongle do you use with a NON-HDTV component connection?  VGA or DVI to component?
Thanks,
Southpaw
somunny
  • Is it hot in here?
Re:ATI Dongle question
« Reply #1 on: September 02, 2004, 05:58:47 pm »
I think it depends on which model ATI card you're using.  And that model is...?
southpaw13
  • Whatever!
« Reply #2 on: September 02, 2004, 08:07:45 pm »
Not purchased yet!  I was thinking of getting the DVI one because I could then run two monitors if needed (assuming the card I buy has support for two monitors).
The specs on both dongles look identical so I am going to assume that it really doesn't matter which one I get.
southpaw13
  • Whatever!
somunny
« Reply #4 on: September 02, 2004, 08:40:37 pm »
I don't think so.  This site has all the info you need.
www.ati.com/support/issuetype/hdtv.html
somunny
« Reply #5 on: September 02, 2004, 08:45:03 pm »
Hmmm...  I don't think I really answered your question.  ;)
You *can* use the HDTV adapter with a regular TV that has component in (and a compatible ATI video card), but don't plan on running the resolution over 640 x 480.  Actually, more like 640 x 432 if you're counting pixels.
southpaw13
  • Whatever!
« Reply #6 on: September 02, 2004, 10:16:39 pm »
Thanks, I got all that stuff from the last thread.  I was just interested in the adapter.  However, the FAQ tells you which dongle to buy...
Thanks,
Southpaw
somunny
« Reply #7 on: September 03, 2004, 02:20:54 am »
So there you go.  :)
