Author Topic: Mamewah config  (Read 2236 times)
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
Mamewah config
« on: September 02, 2004, 12:43:17 pm »
Mamewah is  G:\mamewah.exe
Mame is             G:\mame\mame.exe
and roms are      G:\mame\roms
Mamewah doesnt find any games.
;MAMEWAH v0.97 EMULATOR 1 CONFIG
;LIST GENERATION SETTINGS
ROM Path = G:\mame\ROMS
ROM Extension = ZIP
List Generation Method = 3
;EXECUTION SETTINGS
Emulator Executable = G:\MAME\mame.exe
Send ROM Path = True
Send ROM Extension = False
Use Long Filenames = False
Use Quotes around ROM Filenames = False
Show DOS Box = 2
Default Options =
Extra Options #1 =
Extra Options #2 =
Controls.dat Viewer Filename =
Controls.dat Viewer Default Options =
Launch Controls.dat Viewer before Game = True
IPC Filename / Path =
;MISC SETTINGS
Emulator Title = MAME
Artwork #1 Image Path =
Artwork #2 Image Path =
Artwork #3 Image Path =
Artwork #4 Image Path =
Artwork #5 Image Path =
Artwork #6 Image Path =
Artwork #7 Image Path =
Artwork #8 Image Path =
Artwork #9 Image Path =
Artwork #10 Image Path =
Artwork #1 Filename to Replace =
Display Clone Info (in Custom Lists) = False
« Last Edit: September 03, 2004, 10:04:41 am by itismejs »
wj2k3
  • Last login:August 22, 2006, 12:23:48 am
  • Not!
Re:Mamewah config
« Reply #1 on: September 02, 2004, 02:27:31 pm »
1) Are you using the latest version of MAME?
2) Do you have an up-to-date MAME.DAT file in your Mame directory?
    If not, run the following from the command line in your MAME directory:
              -mame -listxml|xml2info > mame.dat
3) I would change List Generation Method to "2" for Rom Folder Vs DAT File
4) If these are right, then refresh your games list within MameWah by hitting  2-arrow down-1-1  (assumes you are displaying your Main List)
Hope this helps
itismejs
Re:Mamewah config
« Reply #2 on: September 02, 2004, 02:40:20 pm »
didnt do a thing....used that command to make a new dat file (its 16.2 megs)
wj2k3
  • Not!
Re:Mamewah config
« Reply #3 on: September 02, 2004, 04:44:55 pm »
Is your folder actually named "Mamewah.exe" and "Mame.exe"?
If so, delete the ".exe" from the folder names.
pointdablame
Re:Mamewah config
« Reply #4 on: September 02, 2004, 04:49:21 pm »
did you refresh your games list from within mamewah? Games won't show up until you refresh them.
first off your and idiot
itismejs
Re:Mamewah config
« Reply #5 on: September 02, 2004, 05:09:04 pm »
Oh no thats the location plus the file....Should I only have the location of the files?
itismejs
Re:Mamewah config
« Reply #6 on: September 02, 2004, 05:11:07 pm »
Ok now is works but when I close out it says run time error 75 and then dumps me to the destop with the screen size all messed up.
Minwah
    • MAMEWAH
Re:Mamewah config
« Reply #7 on: September 03, 2004, 04:23:48 am »
If you're running Win98, try the workaround here: http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=740&page=0&view=collapsed&sb=5&o=&fpart=1
itismejs
Re:Mamewah config
« Reply #8 on: September 03, 2004, 09:53:40 am »
I have XP.
Minwah
    • MAMEWAH
Re:Mamewah config
« Reply #9 on: September 03, 2004, 09:58:06 am »
I have XP.
Feck, never heard of that before  :-\  All I can suggest is delete your \mamewah\files folder and start again.
Also (not 100% sure) if your mamewah folder is g:\mamewah.exe\ change to g:\mamewah\ as suggested...
itismejs
Re:Mamewah config
« Reply #10 on: September 03, 2004, 10:04:09 am »
I have XP.
the folder is G: .... so mamewah.exe (the program) is just it the root G: folder.
Minwah
    • MAMEWAH
Re:Mamewah config
« Reply #11 on: September 03, 2004, 02:21:36 pm »
Oh right, try installing it to a folder then, eg g:\mamewah\ - maybe it doesn't like being in the root (never tried it myself).
itismejs
Re:Mamewah config
« Reply #12 on: September 03, 2004, 04:05:26 pm »
tried it non root....still didnt work.........
Minwah
    • MAMEWAH
Re:Mamewah config
« Reply #13 on: September 04, 2004, 08:00:16 am »
Haven't got a clue then :(  Hopefully my next release's new config system will fix it - give that a try  :-\
