Author Topic: If someone ELSE built your Mame cabinet you might want to check all the settings  (Read 1100 times)
paigeoliver
  • Awesome face!
I did not build my Gorf mame cocktail, someone else did. I was never quite happy with it. I disliked the joystick being on the right side of the button, and something else just seemed wrong about the games.
I took a serious look at the config today while I was switching the joysticks from 8-way to 4-way.
There were a few issues.
It has a 300 mhz processor, but the motherboard kept detecting it as a 150 for whatever reason. I manually defined it in the bios and now it actually runs full speed.
Mame.cfg had frameskip set to 6, not 0, not auto, but 6. That meant it was only showing every other frame, no wonder the games seemed off.
I had always assumed that the monitor (eygo 19" VGA arcade monitor) was adjusted as good as it could go. Nope, wasn't really adjusted at all. I got the games to actually go full screen with no wasted space and no overscan with only a few seconds of adjustment.
I love the thing now, it is awesome!
iwillfearnoevil
  • Last login:February 13, 2010, 07:08:43 pm
well thanks for telling us of its crapiness _after_ trying to sell it to us ;)
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
He kinda uncrapified it.
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
If your system BIOS detects your CPU incorrectly, the first thing to try is updating the BIOS.
Even if you can manually define it, it may not be using all of the bells and whistles of your chip - such as MMX or SSE. Updating the BIOS only takes a minute and can improve performance, reliability and stability massively; especially on older boards.
