Author Topic: Mounting a sub  (Read 2019 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
Mounting a sub
« on: August 31, 2004, 02:49:49 pm »
Right now my sub is in a box in my cab.  Should I take it out of the box, cut a hole in the bottom of the cab and mount it?  Or will the sound end up being the same anyway?
clonestar
  • Last login:March 09, 2009, 04:00:53 pm
  • Thunderbirds are puppets!
Re:Mounting a sub
« Reply #1 on: August 31, 2004, 05:17:20 pm »
If the sub is in a the box it came mounted in it might not be as good if you take it out.  Speaker cabs are supposed to be designed to have a specific volume of air in relation to the speaker, there are all sorts of calculations relating to vented and unvented sub boxes.  If the sub was cheap then the cab may just be designed on looks, but I would suggest that it might be best to cut a hole and mount the whole box behind it, leaving the sub in the original container.
monkeybomb
Re:Mounting a sub
« Reply #2 on: August 31, 2004, 07:51:26 pm »
I bought the sub and the box separate, but the box is definately designed for a 10"sub.  I like your idea of cutting the whole and using the box also.
thanks
