Author Topic: T-Molding Alternative?  (Read 2038 times)
Tweder
  • Last login:August 31, 2002, 09:38:44 pm
« on: August 31, 2002, 09:40:30 pm »
Hey, I made my cab (www.mamecade.com) with only half inch plywood. I was wondering if I can still use t-molding, or if there is a similar alternative? Thanks
james
  • Last login:September 07, 2002, 09:44:53 pm
  • Granola Handmaster
Re:T-Molding Alternative?
« Reply #1 on: August 31, 2002, 10:16:38 pm »
i believe you're out of luck...
t-molding.com, the main source, has 0 products for 1/2" molding.
You might want to check your local home-depot for a molding that wraps around the wood, and snaps on the sides, as opposed to the routed out t-molding.
james
OSCAR
    • Oscar Controls
« Reply #2 on: August 31, 2002, 11:08:36 pm »
I have tons of 1/2" t-molding in black or white.  It's the smooth style and requires the standard 1/16" slot.  It's currently $.30 per foot.
Email me if you are interested or would like additional info.
Kelsey
info@oscarcontrols.com
