Author Topic: sp2 problems  (Read 1474 times)
daywane
  • GRRRR!
sp2 problems
« on: August 25, 2004, 09:02:49 am »
I just happend to bump into this. thought I should pass it along.  :o
http://support.microsoft.com/default.aspx?kbid=884130&product=windowsxpsp2
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
Re:sp2 problems
« Reply #1 on: August 25, 2004, 01:56:32 pm »
Most problems stem from applications getting screwed up from the new port blocking feature in SP2.  Since MAME and few frontends actually need network connectivity to function, I don't see SP2 breaking anything.
Network play and the like, that's a different story...
Still in the collecting parts and ideas phase of cabinet building.
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
Re:sp2 problems
« Reply #2 on: August 25, 2004, 03:31:48 pm »
I still would NOT recommend installing SP2 on a Mame cabinet unless you feel it absolutely necessary.  If it's not broken, DON'T try to fix it!
  • Last login:Today at 01:40:36 am
Re:sp2 problems
« Reply #3 on: August 25, 2004, 03:42:22 pm »
But the fact of the matter is Xp IS broken.  It's not major things, but they are annoyances that make it worth upgrading.  I've been running service pack 2 for about a week now.  It fixed various minor problems, it's stable, and the new firewall and pop-up blocker make it worth upgrading to.  Btw the firewall doesn't cause any known problems, it's just that it blocks most ports by default and like zone-alarm it asks you if you wish to unblock when one is activated.   Unlike zone-alarm it only asks you once and doesn't flood you with prompts all the time and waste 15-20% of your system resources.  I was rather suprised that not only does it not suck, but it's actually quite good.
Also various older apps or projects I've been working on that use older 98 code magically work now where they didn't before.  Some media player bugs are also fixed, allowing divx and other odd-ball codecs to work better.
Waiting until it's more proven would be reccomended, but you'd have to be a fool to not eventually upgrade to it.  Running a build of windows without the latest patches is like driving a car that's been recalled.  They warned you that it's dangerous so you better go ahead just in case.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
Re:sp2 problems
« Reply #4 on: August 25, 2004, 05:03:47 pm »
yeah dude, howard is right....the reason they put out new patches and stuff is not just cuz they feel like it, but because of security flaws that make pcs suceptable to viruses, etc.  im a sys admin at work and havent pushed out sp2 to our pc's because some of the third party software we have is old and doesnt run correctly, but other than that its great.  i have star wars:knights of the old repblic on my pc and it said that sp2 creates problems with it, but thats just because the firewall blocks ports as howard said.  i run mine through a router, so i just disable the firewall anyway.  that being said you shouldnt have a problem with mame, but you can always create a restore point before you install if you arent sure, that way if it screws up something, you can just go back.
