Author Topic: Lazarus Scancodes???  (Read 4993 times)
bdp
  • Last login:July 28, 2005, 08:27:30 am
« on: August 29, 2002, 09:57:01 am »
I'm giving up the search!  What the HECK scancode table is Lazarus using???  I have yet to be able to find a scancode table where ESC is 27 and Tab is 9.  Can someone post or send me a link to a table of scancodes that works with Lazarus???
Howard: Might be a good idea to put this on the Lazarus site too.  Or include a txt file with the program.  I just have no idea what number to use to remap the interface keys!
Thanks,
Brad
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:Lazarus Scancodes???
« Reply #1 on: August 29, 2002, 10:24:13 am »
As hc and i use the same keycodes a cut and paste from my fe's keylist.txt:
Virtual Key Codes
vk_BackSpace = 8   vk_Tab = 9   vk_Return = 13
vk_Shift = 16   vk_Control = 17   vk_Alt = 18
vk_Pause = 19   vk_CapsLock = 20   vk_Escape = 27
vk_Space = 32   vk_PageUp = 33   vk_PageDown = 34
vk_End = 35   vk_Home = 36   vk_Left = 37
vk_Up = 38   vk_Right = 39   vk_Down = 40
vk_PrintScreen = 44   vk_Insert = 45   vk_Delete = 46
vk_0 = 48   vk_1 = 49   vk_2 = 50
vk_3 = 51   vk_4 = 52   vk_5 = 53
vk_6 = 54   vk_7 = 55   vk_8 = 56
vk_9 = 57
vk_A = 65   vk_B = 66   vk_C = 67
vk_D = 68   vk_E = 69   vk_F = 70
vk_G = 71   vk_H = 72   vk_I = 73
vk_J = 74   vk_K = 75   vk_L = 76
vk_M = 77   vk_N = 78   vk_O = 79
vk_P = 80   vk_Q = 81   vk_R = 82
vk_S = 83   vk_T = 84   vk_U = 85
vk_V = 86   vk_W = 87   vk_X = 88
vk_Y = 89   vk_Z = 90
vk_LWin = 91 *   vk_RWin = 92 *   vk_Apps = 93 *
vk_NumPad0 = 96   vk_NumPad1 = 97   vk_NumPad2 = 98
vk_NumPad3 = 99   vk_NumPad4 = 100   vk_NumPad5 = 101
vk_NumPad6 = 102   vk_NumPad7 = 103   vk_NumPad8 = 104
vk_NumPad9 = 105   vk_Multiply = 106   vk_Add = 107
vk_Subtract = 109   vk_Decimal = 110   vk_Divide = 111
vk_F1 = 112   vk_F2 = 113   vk_F3 = 114
vk_F4 = 115   vk_F5 = 116   vk_F6 = 117
vk_F7 = 118   vk_F8 = 119   vk_F9 = 120
vk_F10 = 121   vk_F11 = 122   vk_F12 = 123
vk_F13 = 124   vk_F14 = 125   vk_F15 = 126
vk_F16 = 127
vk_NumLock = 144   vk_ScrollLock = 145   vk_LShift = 160 **
vk_RShift = 161 **   vk_LControl = 162 **   vk_RControl = 163 **
vk_LAlt = 164 **   vk_RAlt = 165 **   vk_SemiColon = 186
vk_Equals = 187   vk_Comma = 188   vk_UnderScore = 189
vk_Period = 190   vk_Slash = 191   vk_BackSlash = 220
vk_RightBrace = 221   vk_LeftBrace = 219   vk_Apostrophe = 222
Peter
« Reply #2 on: August 29, 2002, 10:36:06 am »
Thanks,
Brad
Well you can redefine keys from within lazarus, so why would I bother?
bdp
« Reply #3 on: August 29, 2002, 03:49:25 pm »
Howard,
I've been having some strange graphics problems with the configuration menu, so I was hoping to do it by hand to make sure that the keys were what I thought they were.
When I start the FE (in Win2000) for the first time, and I hit tab, I can't seem to get the menu to come up unless I move the mouse around and click somewhere.  Then it pops up.
Also, how do I actually select an option from the menu?  Enter doesn't work.  Is the select button the same as the start game button within the frontend itself?  I couldn't find this in the documentation anywhere.
I've been having some trouble getting the FE to work and I followed the setup to a tee.  I'll hafta check out my error messages and get back to you.
Also, sorry if this was covered before, but is there a way to hide the mouse pointer when lazarus starts?
« Reply #4 on: August 29, 2002, 04:12:24 pm »
Howard,
Ok first off check out your skins... the one's on boris's site aren't coded properly and I don't know if it's corrected yet.  Also when the fe starts up you can't immediately go into the tab menu... if you press tab and it disappears just wait a sec and press tab again.
Yes the select key is universal to the fe as are all keys... consult the navigation section of the online manual for more questions on that.
The mouse pointer should disapper after it's not used for a few secs.  Don't use it for navigation and you won't see it.  :)
All known errors are user errors at this point, so be sure to check out your configuration settings.  But if you find something or still can't get it to work email me with a copy of your configuration files.
