Author Topic: How to mount marquee with my setup?  (Read 1237 times)
skid_68
  • Last login:December 29, 2022, 07:25:30 pm
  • Hmmmmmmmm....
« on: August 24, 2004, 01:55:46 am »
Could you guys tell me the best way, and the best things to use to mount my marquee with how I have my cabinet setup. This pic shows how I have the cab built right now. But I could change the way speaker board is cut on the marquee end.(see pic) Wich way should I cut the end to help with mounting the marquee. Also, is it better to have the light right behind the marquee, or would it be fine on the top cabinet board?
MrArcade
  • Last login:May 29, 2025, 02:06:06 pm
  • I wish I had time to play these games !!!
Re:How to mount marquee with my setup?
« Reply #1 on: August 24, 2004, 01:48:16 pm »
I would do the "or this" so it has a flat surface to rest on.
you would probably want to mount the light fixture to the "ceiling" of the cabinet
Oh, the memories of living on pizza subs and Dr Pepper...
skid_68
  • Hmmmmmmmm....
« Reply #2 on: August 24, 2004, 05:21:26 pm »
I was thinking that too. But how do I go about mounting the Marquee/holder and still be able to get it off to get to the light easily?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: August 24, 2004, 06:04:04 pm »
Top bracket should be unscrewable from the top.
Remove.
Slide marquee up and out.
Access granted to light fixture.
NO MORE!!
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #4 on: August 24, 2004, 07:26:17 pm »
You can always make a wood frame to hold it in place and hinge it from the top, see my cab. It doesn't have to be fancy like mine it could be simple and painted black to match your cab if your cab is black that is.
Gary
