Author Topic: Ultimarc VS Happ Joysticks  (Read 1572 times)
terryd
  • Last login:October 27, 2005, 03:14:58 pm
  • To each his own... Unless I want it first!
« on: August 19, 2004, 11:57:58 am »
I want to build an Arcade cabinet and am looking at using either the Happ Competition 8 way Joysticks or the Ultimarc T-Stick Plus...
The benefit of using the Ultimarc is that they are switchable 4/8 way from the top.  You simply pull and twist the shaft to make the switch.  But, I've also heard good things about the Happ model.
I'm hoping that someone out there would have experience with either or both of these Joysticks and can help me make a decision.
Thanks,
-Terryd
pointdablame
Re:Ultimarc VS Happ Joysticks
« Reply #1 on: August 19, 2004, 12:05:40 pm »
They are both good sticks, so you probably aren't going to get someone here to bash one and tell you to get the other (not that you were looking for that).  It really depends on what you are looking for in a joystick.  They both have different feels.  The switchable 4/8 ways aspect of the Tstick is a dealmaker for a lot of people, and you don't have that with the Comp.  Some prefer the Comp for fighters, some even the Super for fighters.  It also depends on what games you play most to an extent.
They will both work, and both will have fans here on the board.  I'd say you should consider getting one of each if you're ordering from Happ and Ultimarc anyway, but I don't know if that is the case.  That way you can try both, still have a 4way to use, and make your own decision.  Worst case scenario: you decided to get 2 of the same stick, so you have to sell one here.  It won't be too hard for you to sell either of those joys in the FS board.
Just my .02      Someone here will probably be able to give you a much more technical breakdown of the differneces, I just prefer to play with them and see what I like more.
first off your and idiot
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« Reply #2 on: August 20, 2004, 10:32:56 am »
I see so much talk about the t-stick plus, but no one ever mentions the omnistick prodigy.  I love that stick.  As mentioned in this post, I have nothing bad to say about the other sticks, but check out groovygamegear.com too.
GGKoul
  • Cheesecake Apprentice
« Reply #3 on: August 20, 2004, 10:43:07 am »
You may want to check out Kevin Steel's review of various joysticks
http://www.retroblast.com/hardware.html
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« Reply #4 on: August 23, 2004, 07:40:42 pm »
Well, the 4-8 way switchability of the T-Stik Plus is not to be underestimated.  I had a friend over who's a Donkey Kong Jr fiend and was having a lot of trouble until I switched the stick to 4-way on the fly; within two seconds he said "OH YEAH... this is WAY better".
So I like the T-stiks because of that.  But even without that they are nice tight responsive sticks, albeit a touch "clicky".
-->VPutz
