Author Topic: Almost finished installing cap kit (WG K7193)  (Read 1698 times)
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« on: August 18, 2004, 02:08:38 pm »
I've installed 17 of the 18 new caps on my WG K7193 PCB but I cannot see C204 anywhere...
I've downloaded the schematics in a .pdf and I can't see it in there either!
All help greatly appreciated.
menace
Re:Almost finished installing cap kit (WG K7193)
« Reply #1 on: August 18, 2004, 04:08:09 pm »
check the neckboard.
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #2 on: August 18, 2004, 04:13:40 pm »
That's the little PCB attached to the end of the tube right?
I was hoping I wasn't going to have to remove that...
How would I go about removing it? Just pull it back away from the tube or is there a catch or something? I can't see anything obvious.
Thanks.
MonitorGuru
« Reply #3 on: August 18, 2004, 04:41:09 pm »
Depending on who put it together, it may either slide right off, or be "glued" to the tube with some silicone rubber caulk .  Also look for any signs of zip ties or something that may have been put on by a 3rd party to keep it from falling off at some point.
You will probably need to disconnect the black ground wire the attaches to the metal strip or spring that touches the outside of the tube, and remember where to reattach it.  The rest of the wires you can leave in place as they should allow you to move it out farther.
Be very carefull removing it.  It should slide DIRECTLY off the back. Do not twist or rock it unless absolutely necessary, and if so, only move it no more than a milimeter each way to help unseat it, otherwise you will end up either breaking the pins out of the tube or cracking the neck as it's very very thin glass back there.
If there is caulk holding it on then take a brand new sharp utility knife and cut a line through it in a circle all around the tube until you reach the glass of the tube, pressing VERY VERY lightly (thats why you need to use a brand new blade).  Lightly pull on the neckboard while cutting to see where you may need to cut deeper.
Good luck
DaveJ-UK
  • Dirty Dawg
    • ChronicGames.NET
« Reply #4 on: August 18, 2004, 05:13:06 pm »
Thanks a lor Guru, that's exactly what I needed to know!
I had tried pulling it like you say but I didn't have the balls to pull it hard/far enough without knowing exactly what I was doing!
I now have the neck board disconnected and have removed the old cap. Unlike all the others on the main PCB, there is no + marking.
Instead, on the circle indicating where the cap. goes, there's a blob on one of the holes. Is this +ve?
Thanks again.
