Author Topic: Had a brainstorm...  (Read 1679 times)
vader
  • Last login:December 27, 2025, 08:14:42 pm
  • I can't breathe in this thing !!
Had a brainstorm...
« on: August 17, 2004, 09:40:56 pm »
and I use that word lightly......can I just tap into the power on the interface board on the USB Happs trackball to power the led light for the translucent ball....if I remember correctly, usb supplys 5 volts so this should work......I think
Tim
paigeoliver
  • Awesome face!
Re:Had a brainstorm...
« Reply #1 on: August 17, 2004, 09:44:19 pm »
Tap into your power supply instead, as the USB bus has a limited amount of 5volt power.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: August 17, 2004, 10:55:39 pm »
a 13v  light, tapped into your PS's 12volt line will probably be brighter than a 5v light.......
(but I'm no expert so I shouldn't be adding my 2 cents here.  ;D )
NO MORE!!
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #3 on: August 17, 2004, 10:56:02 pm »
its doable, but you have to worry about whether or not you will be using other usb devices.  if you hook it into a powered usb hub, you wont have to worry as much..
DaveMMR
« Reply #4 on: August 17, 2004, 11:12:49 pm »
It's probably better to put the power supply at risk of shorting than the USB ports and the motherboard (as is my understanding).
(I'm no expert either, just reciting what I learned from others).
fredster
  • Grand Prophet of Arcadeology
  • Last login:February 16, 2019, 04:28:53 pm
  • It's all good!
« Reply #5 on: August 18, 2004, 12:12:17 am »
Is that so you wouldn't have to run a wire except for the USB from the trackball to the PC?
King of the Flying Monkeys from the Dark Side
vader
« Reply #6 on: August 18, 2004, 12:23:13 am »
Exactly....that is what I wanted to accomplish.....but if it will cause problems,  I can do it the way others are suggesting.......I definitely go with a high wattage bulb if I have to run the power wire....
thanks all
Tim
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« Reply #7 on: August 18, 2004, 08:27:47 am »
I was wondering the same thing to power my 5v lcd panel...
There are two pins on the IPAC that supply power and a ground...
If you are using an IPAC, try getting power from there.
