Author Topic: Will this Router Bit work?  (Read 3461 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« on: August 12, 2004, 07:20:18 pm »
I have been searching high and low for a router bit for the T molding and I came across a 1/8 inch slot cutter, now this would be 4/32 inch bit, and I believe the book (Project Arcade)  says to use a 3/32 inch bit. How much can 1/32 of an inch difference be, thats like a grain of salt, so can I use this bit? I really need a reply soon.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
Re:Will this Router Bit work?
« Reply #1 on: August 12, 2004, 07:38:03 pm »
i believe the standard bit everyone uses is 1/16th.  anyone that has used the 1/8" slot cutting bit has found that they need to use hot glue to keep the t-molding in.
Apollo
    • Eight Bells
« Reply #2 on: August 12, 2004, 07:43:03 pm »
Ditto, hot glue gun will do the trick.
the3eyedblindman
« Reply #3 on: August 12, 2004, 07:47:41 pm »
No, I would rather just get the right bit, anyone have one or know where i can get one? I dont really wanna have to catalog order at home depot, would just like to pick one up.
lindart
  • Last login:January 07, 2014, 07:04:36 pm
    • The Place To Be
« Reply #4 on: August 12, 2004, 08:38:11 pm »
mlcswoodworking.com has them for $16 shipped.
rdagger
« Reply #5 on: August 12, 2004, 09:04:09 pm »
If there is a Rockler Woodworking center in your area, they carry the 3/32".
http://www.rockler.com/ecom7/product_details.cfm?&offerings_id=2119
Amazon sells the 1/16" Freud slot cutter, which is excellent, but expensive.
reebboy
  • Last login:December 12, 2005, 01:34:53 am
  • Now its time for some serious insanity!!!
« Reply #6 on: August 12, 2004, 09:12:43 pm »
Here is the direct link to the 3 wing slot cutters on mlcs. This is the best deal in town. They don't charge for shipping in the USA either.
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
Dude!!! Where's my game.....
old school gamer
  • Last login:December 22, 2006, 02:20:28 pm
  • Woodworking Genius, computer illiterate!
    • my homepage
« Reply #7 on: August 12, 2004, 10:33:15 pm »
16$ is a bargin (no shipping ) I would jump on it! By the way,you do not want to make the slot to big and put hot glue it in. I know there are lots of people saying that this works,but you have come this far,why half ass it. Do it right and you will be happy. Peace OSG
My tag line was inappropriate for a family oriented site. It has been changed by saint.<-- THATS better than anything I could have come up with!!!!!!! Thanks Saint!!!-
Mameotron
« Reply #8 on: August 13, 2004, 02:12:49 am »
Yeah, jump on that $16 deal.  I paid $20 for mine a few years ago.  And getting it online is probably the best way to go.  I remember I had to go to every store in town before I found a 1/16 slot cutter.
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
« Reply #9 on: August 13, 2004, 02:21:03 am »
Agreed.  1/16" is definately the way to go.  And that price is excellent.  Expect to find it for $30 everywhere else.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #10 on: August 13, 2004, 10:14:18 am »
It seems that everyone uses 1/16", but I have seen many comments that that size makes for a very tight fit and removing the molding causes some damage to the slot (removing MDF, ply etc.).
I used 3/32" on 5/8" molding and the fit is perfect. It's strong enough to hold without glue (I just fit it with a rubber mallet) and I can remove the molding without tearing any wood out of the slot.
saint ganked my avatar.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #11 on: August 13, 2004, 10:27:33 am »
Why would you remove it after you build it?
I also got the bit from MCLS.  Can't say enough good things about it.
atog
  • Last login:January 30, 2015, 04:07:36 pm
« Reply #12 on: August 13, 2004, 10:46:19 am »
1/16th is a VERY tight fit, you will need to use a rubber mallet to seat the T-molding in the slot.  Note: this isn't necessarily a bad thing, it leaves a very professional looking job when seated.
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
« Reply #13 on: August 13, 2004, 10:47:22 am »
FWIW, cutting the slot a little oversized and using glue to snug it isn't really "half assing it."  It's just a different way of going about it.   Same outcome for a little more hassle and less money.  I've done it both ways, and it looks the same.  That's all that matters.
If you can't be a good example at least try to be a horrible reminder.
FractalWalk
  • Newbie
« Reply #14 on: August 13, 2004, 11:10:37 am »
In my case, it was due to a re-design that required, altering the cab front.
I agree that most people won't need to remove it but it doesn't hurt to have the option.  Plus, IMO it is designed to be removable without damaging the cab (similar to auto fasteners).
I just think 1/16th is too narrow a cut.
ThePaul
  • Last login:August 07, 2008, 02:57:16 pm
  • The Second to The Last Star Fighter
« Reply #15 on: August 13, 2004, 11:16:05 am »
I used 1/16th bit and have removed the T-Molding twice. Did not have any problems.. I was very careful... and after the third application the T molding still holds in firmly. It might be a matter of luck.
rdagger
« Reply #16 on: August 13, 2004, 12:18:20 pm »
I'm doing the 1/16" right now.  It does require a mallot and the corners are difficult because the tip of the molding starts to flex and doesn't want to go in.  However, once seated it does look very good.
I removed a small piece and it did have a tiny sliver of MDF stuck to it.  Maybe 1/64" -- not enough to make the replacement piece loose or even easier to install.
atog
« Reply #17 on: August 13, 2004, 12:35:08 pm »
There is a trick to notching the inside for corners.  Professionals have a notching tool, which is sold on some arcade websites for over $100.  I used my wifes good scissors while she wasn't looking, and they worked fine.
enchntr
  • Last login:January 23, 2013, 07:49:56 pm
  • All Around Star Wars Nut
    • Power of the Force.com
« Reply #18 on: August 13, 2004, 04:51:13 pm »
I used a good utility knife and notched the inside and outside corners.  Worked flawlessly.
Ed
marsmarvin
  • Last login:August 26, 2004, 12:21:47 pm
« Reply #19 on: August 13, 2004, 05:25:49 pm »
I bought a 3/32 inch slot cutter from mlcswoodworking.com and it was too big.  I'll need to use glue to finish my project.
Go with 1/16.  I will on my next cab.
I did get good service from mlcswoodworking, though.
rdagger
« Reply #20 on: August 13, 2004, 06:01:18 pm »
Ed
Could you explain how the notches should be cut?
marsmarvin
« Reply #21 on: August 16, 2004, 05:01:31 pm »
Could you explain how the notches should be cut?"
Spystyle has a good explaination with pictures about 2/3rds down this page:
http://spystyle.arcadecontrols.com/index4.htm
marsmarvin
« Reply #22 on: August 16, 2004, 05:04:33 pm »
By the way, I said last week that I'll need glue with the 3/32 inch slot, but I was wrong.  It turns out that after painting, 3/32 is not too big afterall.
Sorry I doubted Saint.
atog
« Reply #23 on: August 16, 2004, 05:41:37 pm »
yep basically how it's shown in that picture, just remove some of the slot in the area where it has to bend around the corner.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #24 on: August 16, 2004, 05:54:30 pm »
I also ordered my slot cutter from MLCS, and I was very pleased with the speed of shipping.  I can't recommend them enough.
skid_68
  • Last login:December 29, 2022, 07:25:30 pm
  • Hmmmmmmmm....
« Reply #25 on: August 16, 2004, 08:45:44 pm »
Is this the one you guys are talking about? The three wing slot cutter?
http://www.mlcswoodworking.com/cgi-mlcswoodworking/sb/order.cgi?rd=1&storeid=*1aab4045b0f44c9a035e7cae718b4c&sbid=SSMSB1092703371.28273&prevlocation=http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html
RacerX
« Reply #26 on: August 16, 2004, 09:49:58 pm »
That's the one I bought!
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« Reply #27 on: August 17, 2004, 12:43:12 am »
I bought that one too.  It worked like a charm, and as Peale said before...it cuts through like butter!
krick
  • Gotta have blue hair.
« Reply #28 on: August 17, 2004, 09:53:09 am »
T-Molding.com sells a 1/16 slot cutter...
http://www.tmolding.com/cart/customer/product.php?productid=38&cat=5&page=1
T-Molding slot cutter assembly for a router.
Includes arbor, bearing, cutter, and nut.
Use with molding 3/4" wide and smaller.
Shank Diameter: 1/4" (shaft width)
Cutter Height: 1/16" (slot width)
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
MonitorGuru
  • Last login:October 05, 2005, 11:29:43 pm
« Reply #29 on: August 17, 2004, 11:28:47 am »
I used a 5/64's I borrowed from a friend who bought it online and it was perfect size.
(1/64'ths bigger than 1/16", 1/64'ths smaller than 3/32).  Worked great in oak laminated MDF and melamine laminated particleboard.  Didnt try plywood.
Too narrow and you are likely to split the MDF pounding in the molding since MDF splits very easily.
I'd go 5/64ths if at all possible.
Alternately, you cold use the 1/16 and then route it from one side, then flip over and do it from the other side. The chance of you getting it "exactly" in the center on the first route is very small so doing it from the other side (only works if you havn't built the cab yet, just the raw piece) you would end up making it a tad wider.  Or simply adjust the plunge by 1/64th of an inch and reroute from the outside.
foomench
  • Last login:September 28, 2010, 02:56:19 am
  • I'm not a llama!
« Reply #30 on: August 17, 2004, 01:38:19 pm »
I looked at that MLCS page and found this: "Bit #5360 is designed for T-moldings."
But there is no #5360 on the page. Anyone know what width that was?
I do see that they have a 5/64" width bit. Guess I'll get that.
-foomench
