Author Topic: LOCK BUTTONS MAMEWAH  (Read 1913 times)
scottyarc2
  • Last login:November 10, 2005, 05:33:53 pm
« on: August 12, 2004, 07:11:46 pm »
Is it possible to lock out the menu on mamewah, So if player 2 start button is pressed the menu is NOT brought up!! I want to run up mamewah now i have configured it and dont want it to be accidently tampered with??
scottyarc2
Re:LOCK BUTTONS MAMEWAH
« Reply #1 on: August 12, 2004, 07:12:51 pm »
Note i will also need to setup a shift key arrangement to exit out and shutdown!!!
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #2 on: August 13, 2004, 02:01:59 am »
Yep, Mamewah has this built in.  Just hold down player 2 start for 3 seconds and the menu will be locked.  Do the same to turn it back on.
scottyarc
  • Last login:July 20, 2004, 03:01:03 am
« Reply #3 on: August 13, 2004, 09:52:25 am »
Is there a way to change this so mamewah starts automatically with the menu locked and not unlocked which is the default???
Minwah
    • MAMEWAH
« Reply #4 on: August 13, 2004, 01:32:15 pm »
Yes, lock MW, and exit using the Exit Button.  Next time you start it up it will be locked (& will be locked forever until you unlock it).
scottyarc2
« Reply #5 on: August 13, 2004, 05:09:18 pm »
Splendid, Thanks again, great FE
scottyarc2
« Reply #6 on: August 13, 2004, 05:35:57 pm »
Now that the menu is locked is there a way to exit via a combination of buttons?? as i usually go into the menu to exit, so with no menu not sure how to exit/shutdown????
Minwah
    • MAMEWAH
« Reply #7 on: August 14, 2004, 01:50:31 pm »
By default the Exit Button is Escape (remap in Control Options > Customise Controls).  Set the Default Exit Button Action to determine whether it quits to Windows/shuts down etc...
scottyarc2
« Reply #8 on: August 15, 2004, 07:35:42 am »
I remapped to player 2 button 3 and this works until the menu is locked?? when the menu is locked it wont work and i cant exit without unlocking???
Minwah
    • MAMEWAH
« Reply #9 on: August 15, 2004, 11:16:33 am »
What key is your 'player 2 button 3'?
