Author Topic: Omnicade Arcade System!  (Read 2808 times)
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
« on: August 11, 2004, 03:55:34 pm »
www.omnicade.com
any one use Omnicade .
i am so much tired to get a further information my self. ;)
don't want any more experiment ,right now.
i have seen it,while i was searching for some other matter.
plz tell me what is it....?
BLUE BIRDS FLY WITH BLUE BIRDS
Wizard of DelRay
Re:Omnicade Arcade System!
« Reply #1 on: August 11, 2004, 05:48:43 pm »
Apparently not worth the hassle. http://retroblast.com/reviews/omnicade.html
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #2 on: August 11, 2004, 06:15:45 pm »
You might want to try Fraggle's boot disk. It uses an older version of Mame, but  it worked pretty well on one of my mame systems.  I think it uses Mame.62, and the older version of Arcade OS, but you can probably swap things out here and there and get your systems running with mame85?
http://mame.how.to/
  • Last login:January 29, 2026, 09:50:33 pm
« Reply #3 on: August 11, 2004, 06:34:21 pm »
Here's the thing about those boot discs, and I hope I don't offend anyone by this.  They pretty much suck.  They are great if you have similar hardware to the person who authored them and pretty much don't want to alter any of the settings they used.  Unfortunately if that is not the case, it's often so cumbersome to go into the image and change things that you are often better off simply installing all the software manually.
Mind you setting up linux can be tough, but setting up mame is laughably easy. And these cds that utilize advancemame aren't particularly helpful as, again, the settings they have set probably aren't the settings you would use.  And since installing advance mame isn't the hard part, rather configuring it you are probably better off just setting it yourself.
I think it's a good concept, it's just these cds need a lot more work before they are really the turn key solution they advertise themselves to be.
btw i'm just talking in general, so ignore any details that don't apply specifically to this particular boot cd.
