Author Topic: ArcadeVGA Sanyo 20EZ 19" Arcade Monitor  (Read 1336 times)
chrisinauz
  • Last login:February 21, 2005, 01:07:54 pm
« on: August 11, 2004, 03:06:44 am »
 I have the following setup and its working great, I used the AVRes utility to set it up with MAMEWah and most games work good, but a lot of games, mostly newer ones, like Marvel VS Capcom or XMen VS Street Fighter, or even Tempest come up with CRAZY verticle scrolling, this is obviously a refresh rate problem not a resolution problem right? Any ideas? I've tried editing the INI files made my AVRes and changing resolutions to no avail! Please help!
chrisinauz
Re:ArcadeVGA Sanyo 20EZ 19" Arcade Monitor
« Reply #1 on: August 11, 2004, 03:15:54 am »
Also the "640X288" Resolution in MAMEWah thats suppose to give Flicker Free Resolution does not work IE. Gives me crazy horizontal scrolling!?
chrisinauz
« Reply #2 on: August 11, 2004, 03:28:59 am »
Ahh I seee its just tweaking the resolutions, I found 368x240 to work well with Marvel Vs Capcom and stuff its close to the original, is there anyway to redo the .INI files quicker??
chrisinauz
« Reply #3 on: August 11, 2004, 03:35:34 am »
Anyone know why some of the INI's I can edit to the correct resolution and they run good, but others when I put the SAME resolution, I get crazy verticle scrolling!!! GRRR
