Author Topic: diy monitor bezel ideas  (Read 8225 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: August 10, 2004, 10:27:50 am »
just thinking of alternative ways to make a custom sized monitor bezel for my cocktail cab (instead of cardboard)
how about foam like you get in packing of electrical goods etc.
for example on this site...
http://www.myfoam.com/products.cgi?cart=&item=packing
what about some long thin lengths of the Ester Foam in the Clipped bolster shape. Then just mitre then together to form the bezel?
probably too expensive
just an idea
« Last Edit: August 10, 2004, 10:29:31 am by rchadd »
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
Re:diy monitor bezel ideas
« Reply #1 on: August 10, 2004, 10:43:39 am »
what about making a bezel out of wood for use with a wood colored cabinet?
Witchboard
  • Last login:January 05, 2022, 09:09:24 pm
    • Oklahoma Coin-Operated Collectors
« Reply #2 on: August 10, 2004, 10:48:45 am »
I would think the foam would attract more dust and be more difficult to clean since it's a porous material.  You could always try it and if it doesn't work out, try something else.
rchadd
  • Made in Cornwall
« Reply #3 on: August 10, 2004, 10:54:53 am »
it would be under the table glass so dont think dust would be a problem.
figured foam would be easy to trim to fit the curvature of the monitor and give a good fit.
personally i would have paid for a happ bezel but my monitor is 21" and figured it will be just too big for their 19" bezel.  In some ways size is not always better;)
I could have saved a lot of hastle on building my cab if i had got a 19" monitor - ain't hindsight wonderful?
Witchboard
« Reply #4 on: August 10, 2004, 10:58:32 am »
If you have fans running in your cab, you'll be surprised where dust can get,  especially when you have static from the monitor.
rchadd
  • Made in Cornwall
« Reply #5 on: August 10, 2004, 11:07:23 am »
i am wondering if i can get some sort of black rubberized material like stuff the are used on cars to give watertight seal on the boot lid (trunk???).
cardboard beginning to seem like a easier option
whammoed
  • Last login:February 27, 2026, 04:03:09 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #6 on: August 10, 2004, 11:13:49 am »
I didn't use foam as a bezel but I did use it to block the small amount of light that showed through between the bezel and the monitor.  Worked really well and no dust problems(had fans too)  I think it is a good idea...use some cardboard or foam core board with the thick foam on the back...shouldnt need to trim for the curve of the monitor, it should be squishy enough to press nicely against the glass.
BTW this is not an original concept:
http://www.happcontrols.com/monitors/49074100.htm
Witchboard
« Reply #7 on: August 10, 2004, 11:15:00 am »
They sell a rubberising agent in a spray can.  You could make a bezel following these instructions and then coat it with the rubber in a can.  Hmm.. that may not be too bad of an idea.
Goz
  • KOTA
« Reply #8 on: August 10, 2004, 11:25:22 am »
I've had pretty good results with "Black foam poster board". You can get this stuff at Office Max, Office Depot, Staples, etc. You can see a picture of the stuff here http://www.framingsupplies.com/MatBoardFoamBoard/FoamBoard.htm
You can get it in many sizes and it has a nice protective outer layer.
I typically find it local for about $5 for a sheet large enough to make a 25" bezel.
Hope this helps
-Goz
rchadd
  • Made in Cornwall
« Reply #9 on: August 10, 2004, 12:05:48 pm »
Hope this helps
-Goz
hey this stuff looks good - i'll need to find a supplier in the UK
gajaman
  • Last login:July 19, 2011, 02:50:33 pm
  • The GajaCab is here......
    • The Gaja Project
« Reply #10 on: August 10, 2004, 02:58:40 pm »
I made my own from a sheet of mounting board and some strips of wood I had laying around.
I don't have much patience but it worked out well. Still looks good two years on!
Some pics/basic instructions on my site:http://www.gajaproject.pwp.blueyonder.co.uk/arcade/
Chris
    • Chris's MAME Cabinet
« Reply #11 on: August 10, 2004, 08:58:59 pm »
Make sure whatever you cut it with is SUPER sharp and cut slowly!
--Chris
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #12 on: August 10, 2004, 11:41:02 pm »
On my cocktail I used black wetherstripping (the stuff you use around windows to make a seal) I'll say that I do have a flatscreen PC monitor so it does work fairly well. If I had a curved monitor I don't think it would work since the weather stripping is only 1/2" thick and a curved monitor at it's widest point is easily more than 1/2". The other think with my cocktail and weatherstripping is that I wish I had made the monitor hole a little larger in the top. Looking at the screen from an angle like you do from sitting at a chair, it does obscure the bottom of the screen. All said and done if I had to do over again I think I would make a cardboard bezel since I could then make it so I didn't have the bottom obscured view problem.
The top really doesn't obsucre that much, pretty much only how many lifes you have left or maybe the score sometimes but it'd be nice to have nothing obscured. I could fix it by adjusting the monitor but I guess i'd rather have the monitor larger. All said and done, bezel is the way to go
rchadd
  • Made in Cornwall
« Reply #13 on: August 25, 2004, 08:36:36 pm »
decided to try making something with happ sticky vinyl
doesnt have to be perfect as will be under grey tinted glass
