Author Topic: What speed Pentium 3 to run the classics??????  (Read 1023 times)
koolmoecraig
    • My Intervention
« on: August 09, 2004, 01:57:02 pm »
Hello all,
I am trying to make a MAME cabinet on the cheap and I was wondering what would be the slowest processor speed(P3) that would run games perfectly smooth on an arcade monitor thru an ArcadeVGA?
I just need the classics to run at full speed(Donkey Kong, Pac-Man, Frogger, etc) Pretty much nothing made after 1987.
Thanks for the help!
Craig
menace
Re:What speed Pentium 3 to run the classics??????
« Reply #1 on: August 09, 2004, 01:58:55 pm »
I ran a 450 with no problems.
whammoed
  • Last login:Yesterday at 02:40:57 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #2 on: August 09, 2004, 02:00:19 pm »
I don't believe you will have any trouble with those games on any P3.  Should actually be fine with a P2.
MonitorGuru
  • Last login:October 05, 2005, 11:29:43 pm
« Reply #3 on: August 09, 2004, 04:26:41 pm »
See my post from last nite here called "P166 vs Cel366"   Using AdvanceMame though and an off the shelf old PCI video card.
As the previous poser said, with that set up, you should be able to run the classics on a least P2/Celeron technology starting around 266/300 MHz at full speed.  However that assumes you are drawing at low res, from DOS without the overhead of Windows and video card drivers and scaling and etc..
