Author Topic: Problems with vertiwah  (Read 1182 times)
Johnny
  • Last login:January 12, 2026, 07:16:27 pm
  • I Want My Own Coctail Cabinet!!
« on: August 08, 2004, 07:09:23 pm »
Hi Guys,
I do need som help on vertiwah as I can't get it to run. :-\
When clicking on the vertiwah.exe, I do get the following error: (not yet run config.exe)
"system error &H8007007E (-2147024770) The specified molule could not be found"
Also, the basicbw folder (skins/basicbw) is empty. I'm shure I'm missing the background pictures, as the basicbw.ini is there. (the zip file is dowloaded from the vertiwah homepage.)
thanx
Johnny
Johnny Andersen
 Oslo - Norway
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
Re:Problems with vertiwah
« Reply #1 on: August 08, 2004, 07:16:33 pm »
Actually, there is no background image for the basicbw skin. If you're encountering that error, you probably didn't set it up correctly.
Try this:
1. use the Configuration program to edit everything to your liking.
2. edit emudat1.cfg to match your system settings
3. make your own skin, and make sure to set all the different options for each of the items there (in the skin making app)
4. Look in vwah.ini under "[Plug-ins]" (if it exists), and make sure NumberOfPlugins=0
Hope that helps,
EndTwist
Johnny
« Reply #2 on: August 08, 2004, 07:38:27 pm »
Thanx for the reply.
I have now done all config. possible, still the same error!  ???
(Looks like I have to stick with Glaunch)
- Johnny
Johnny Andersen
 Oslo - Norway
EndTwist
  • Arg.
« Reply #3 on: August 08, 2004, 08:25:14 pm »
You've even created your own layout, being careful to set every thing? If not, do that. If it still doesn't work, email me these files:
vwah.ini
emudat.cfg
my email is: endtwist]at[gmail.com
Edit: Also, have you generated your own game list?
« Last Edit: August 08, 2004, 08:26:06 pm by EndTwist »
Johnny
« Reply #4 on: August 08, 2004, 09:27:13 pm »
Hi Endtwist,
No, I have not created any layouts, I don't have the skill to do that (That's why I have been using glaunch ;D ), but I did make the game list. So, until I can find some ready made layouts, I would not use Vertiwah.
Anyway, thanx for Your offer!
- Johnny
Johnny Andersen
 Oslo - Norway
