Author Topic: D9200 dark patch  (Read 1546 times)
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
D9200 dark patch
« on: August 06, 2004, 11:30:07 am »
The top right hand side of my D9200 has a darker area on the screen top left side, it is very miner so I don't really want to try taking it out of the cab and degaussing it at an angle which I know works sometimes. I did try just degaussing it in the cab but with no effect.
Would a manual degaussing ring fix this?
Gary
Ghoward
  • Mame rocks!!
Re:D9200 dark patch
« Reply #1 on: August 08, 2004, 07:56:22 pm »
Someone must be able to help me out here!
Gary
whammoed
  • Last login:Today at 02:40:57 pm
  • Crack don't smoke itself
    • NiceMite
Re:D9200 dark patch
« Reply #2 on: August 08, 2004, 08:31:03 pm »
Well, I have a d9200 with a slight color problem in one spot.  (I wouldn't necessarily call it darker, just different color)  The onboard degaussing does help but I think it may be inadequate.  I have purchased a manual degaussing coil to try but have not got around to doing it yet.  I will let you know how it goes.  I am assuming it is stubborn because it is upside down in my cocktail cab as I didn't notice anything when i first used it upright.  It is a minor problem, I am the only one who notices.
Ghoward
  • Mame rocks!!
Re:D9200 dark patch
« Reply #3 on: August 08, 2004, 10:02:44 pm »
That sounds a bit like mine maybe dark spot wasn't the best wording I could have used. I look forward to hearing what happens when you try your coil.
Gary
