Author Topic: IPAC driver issue  (Read 1962 times)
PiNPOiNT
  • Last login:November 19, 2010, 05:00:59 pm
IPAC driver issue
« on: August 05, 2004, 05:49:41 pm »
Every time i start my mame cabinet my ipac is not getting registered by my computer, and when i check in device manage it has a exclamation point on it, and the note says "this device has a problem its registry entry is damaged or corrupted.   The only way i can fix it right now is to uninstall the device and have windows find and re install it again.  Is there a update driver i could use?  im just using the standard one that windows installs when you plug in the IPAC
any ideas?
Re:IPAC driver issue
« Reply #1 on: August 05, 2004, 07:46:24 pm »
Is it in USB mode?  If so maybe try it in PS/2 mode...
Muttley
  • Last login:December 17, 2004, 05:29:42 am
    • MuttleyVille
« Reply #2 on: August 06, 2004, 03:41:21 am »
Are you uploading alternate configurations to  the I-PAC at all?  Got a fast CPU?
I've been working through an issue with my I-PAC with Andy, and it seems that the WinIPAC utility doesn't handle the timings necessary for programming the I-PAC very well if you're running on a fast CPU (Mine's a 3GHz P4).
Mine's OK if I leave it alone and don't try and program it at all.
It's a bit of a pain as it means for some emulators I still need the keyboard accessible, but Andy says he's going to get the loader part of WinIPAC rewritten.
HTH
Muttley
