Author Topic: HELP! I cant get AdvanceMAME to find roms after launching with arcadeos!  (Read 3977 times)
vettetek
  • Last login:October 05, 2025, 10:53:53 pm
Heres a doosie for a first post!
Im a real newbie to this, and Im going to be using an arcade monitor with 1900xp, ATI radeon 7000 series, soundblaster live, arcadeos and advance mame, ect.
The problem I have is I cant seem to get the damn roms to show up under arcade os. Ive played around for like 6 hours just trying to get them set up. I cant find any real good setup procedure on the net for these two programs.
Any help out there?
Oh, and Im runing the current versions of both as well.
~V
vettetek
Re:HELP! I cant get AdvanceMAME to find roms after launching with arcadeos!
« Reply #1 on: August 03, 2004, 02:54:06 pm »
<bump>
I havent seen too many reads on this, ??? and I KNOW someone out there has some sort of tutorial or instructions on how to set up the latest versions of arcadeos and advance mame. I tried using fraggles disk, and the in game graphics go ape when a game is ran (all garbles and whatnot).
~V
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: August 04, 2004, 08:52:19 am »
Since you're using the latest version of Mame, do you have the legacy option marked as '0' in the arcadeos.cfg?
vettetek
« Reply #3 on: August 04, 2004, 02:04:20 pm »
Ill go and check that now. What does the legacy option do and for? Im used to using mame32 on my pc, so this dos-advance mame and arcade os is a WHOLE new animal to me.
~V
vettetek
« Reply #4 on: August 04, 2004, 02:12:29 pm »
Just checked
Legacygen=0 in my arcadeos.cfg file. Anything else to check? Still no-go. ???
thanks
~V
coconut
  • Last login:August 19, 2004, 09:47:57 am
« Reply #5 on: August 04, 2004, 02:45:59 pm »
I Had this very same problem and could not get arcadeos to list the roms either (using advancemame as well).  It was a while ago, but I believe what ended up working was making a second roms directory (avdmame used /roms/ or /rom/)
Check if you have a roms or rom directory. Then make a second one with the other name ie /rom/
Copy a couple of your roms into this directory.  If this works then move all your roms into this one.
Also check in your config file (arcadeos) to see where its looking for your roms, can try changing this as well to match. I tried this but it didn't work.
I had tried countless things to get it to work, so many that I kind of forgot which actually worked.
Best of luck, ;D
P.S. if this doesn't work I have some more idea's for you
SirPeale
« Reply #6 on: August 04, 2004, 03:35:15 pm »
Post both your mame.cfg and your arcadeos.cfg so we can take a look @ them.
Also, delete all your .lst file and the .rnd and .rms files, and try it again.
Oh, and the legacy option is for older versions (pre .84) of Mame, since they used the "-listinfo" option and not the "-listxml" option.
vettetek
« Reply #7 on: August 04, 2004, 09:11:13 pm »
ok...i got the rom folder duplicated to /roms also. Ill go ahead and try Peals idea. Im assuming these are in the Mame directory. Now I am running AdvanceMame - not just mame - does that make a diffrence? Peale, I just PM'd you on yahoo. please get back with me if possible.
Thanks,
~V
vettetek
« Reply #8 on: August 04, 2004, 09:20:27 pm »
Still nothing. Damn. I noticed also that when I run arcadeos, that the first 4 options in the dropdown menu are "blacked out" does this mean that it cant find mame? After I deleted the aformentioned files, it went into generating -list and it said something like c:/-listinfo.xml or something. Is this part of the problem as well?
thanks again
~V
SirPeale
« Reply #9 on: August 04, 2004, 09:48:39 pm »
You still haven't posted the files I asked for.
vettetek
« Reply #10 on: August 04, 2004, 10:13:56 pm »
ok here goes:
its a big one~ heres the arcadeos cfg file first:
# ArcadeOS 2.51 Config File #
#path for mame
mamepath=C:\mame\
#executable for mame
mameexe=advmame.exe
#executable used to get game and clone list
infoexe=advmame.exe
#configuration file used by mame executable
config=advmame.rc
#List of scancodes to remap
remaplist=
#standard AOS backdrop
backdrop=aos.pcx
#standard AOS LCD Logo
lcdlogo=aos.lcd
#Shutdown file for the LCD screen.
lcdshutdown=shutdown.lcd
#File containing LCD info for ROMS
#The .lcd info for a ROM will be displayed when the ROM is launched.
lcdlist=list.lcd
#Custom List names
clist1=list 1
clist2=list 2
clist3=list 3
clist4=list 4
clist5=list 5
clist6=list 6
clist7=list 7
#Joystick actions
j1but1=kp1butt1
j1but2=kp1butt2
j1but3=kp1butt3
j1but4=knxtclist
j1but5=knxtemu
j1but6=
j1but7=
j1but8=
j1select=kpcoin1
j1start=kp1start
j2but1=kp2butt1
j2but2=kp2butt2
j2but3=kp2butt3
j2but4=klock
j2but5=
j2but6=
j2but7=
j2but8=
j2select=kpcoin1
j2start=kp2start
#Command to run for 'switch off'
#if 'extrahardware' is set to 1
switchoff=
#Command to run for 'switch on'
switchon=
#Startup sample, must be in AOS directory
startupwav=startup
#Shutdown sample, must be in AOS directory
shutdownwav=shutdown
#Window sample, must be in AOS directory
windowwav=window
#Error sample, must be in AOS directory
errorwav=error
#Screen saver sample, must be in AOS directory
saverwav=saver
#Game run sample, must be in AOS directory
gamewav=game
#Options passed to MAME for NTSC/Arcade monitor mode
arcmodeopt=-monitor arcade
#Options passed to MAME for PAL TV mode
palmodeopt=-monitor pal
#Type of soundcard to use
#0=Silence
#1=Sound Blaster
#2=Sound Blaster AWE32
#3=Pro Audio Spectrum
#4=Ultrasound Max (CS4231 Codec)
#5=Ultrasound
#6=Windows Sound System
#7=Ensoniq Soundscape
soundcard=0
#Sample rate to use
samplerate=22050
#amount of log information generated to ARCADEOS.LOG
#-1 = game info,brief
#0  = no log
#1  = game info
#2  = full log
logging=0
#format of dates in log file
#0 = mm/dd/yyyy
#1 = dd/mm/yyyy
dateformat=0
#indicates if the log file is cleared down
#0=no clear
#1=clear
clearlog=1
#time in seconds before screen saver kicks in
#(set this to 0 for no sreen saver)
savertime=180
#time in seconds before screen shot is changed
shotdelay=10
#Type of screen shot used (from screen shots/flyers/cab pictures)
#0=standard (always screen shots)
#1=cycle
#2=random
sstype=0
#Mouse X pos
mousex=320
#Mouse Y pos
mousey=100
#Selects video output type:
#0 = Standard VGA Output
#1 = Arcade Monitor / NTSC Output
#2 = PAL TV Output
#DO NOT SET TO 0 IF YOUR PC IS CONNECTED TO AN ARCADE MONITOR/TV
incabinet=1
#640x480 mode
640x480=0
#scanlines - 0=no 1=yes
#hardware scanlines (320x200 mode), half brightness software scanlines (640x480 mode)
scanlines=0
#tweak value for x pos of screen
centerx=0
#tweak value for y pos of screen
centery=0
#Size of AOS's font
fontsize=0
#Display scheme
scheme=0
#Beep through SB if found
beepfm=0
#Transparency
transparent=30
#amount of information displayed by AOS
information=2
#background colour
backcolour=0
#fore colour
forecolour=15
#clone colour
clonecolour=7
#extra colour
extracolour=14
#cursor colour
cursorcolour=5
#Disabled colour
discolour=8
#Indicates the type of joystick
#0 = None
#1 = 2 button joystick/pad
#2 = 4 button joystick/pad
#3 = 6 button joystick/pad
#4 = 8 button joystick/pad
#5 = Sidewinder
#6 = GamePad Pro
#7 = PSX pad
joytype=0
#Current emulator
curremu=0
#random game index
randomidx=0
#Extra printer hardware -
#sends to LPT1 port, bit 0 for monitor power and
#enables monitor rotation hardware through bits 1 and 2 (Right & Left)
printhardware=0
#Other external hardware -
#calls 'switchon' for on
#'switchoff' for off
#you can set these values to be any legal app/batch file
extrahardware=0
#menu locked 0/1
menulocked=0
#screen saver type
savertype=0
#Explode windows
explodewin=1
#last screen shot of last game run
uselastshot=1
#Show screen shots when moving through the list
showshot=1
#display all files found - even if no legal game name is found
unknowns=0
#don't check for new games at startup
instantstart=0
#Orientation of menu
orientation=0
orientation2=0
orientation3=0
orientation4=0
orientation5=0
orientation6=0
orientation7=0
orientation8=0
orientation9=0
orientation10=0
orientation11=0
orientation12=0
orientation13=0
orientation14=0
orientation15=0
orientation16=0
orientation17=0
orientation18=0
orientation19=0
orientation20=0
orientation21=0
orientation22=0
orientation23=0
orientation24=0
orientation25=0
orientation26=0
orientation27=0
orientation28=0
orientation29=0
orientation30=0
#last game run
lastgame=-1
lastgame2=0
lastgame3=0
lastgame4=0
lastgame5=0
lastgame6=0
lastgame7=0
lastgame8=0
lastgame9=0
lastgame10=0
lastgame11=0
lastgame12=0
lastgame13=0
lastgame14=0
lastgame15=0
lastgame16=0
lastgame17=0
lastgame18=0
lastgame19=0
lastgame20=0
lastgame21=0
lastgame22=0
lastgame23=0
lastgame24=0
lastgame25=0
lastgame26=0
lastgame27=0
lastgame28=0
lastgame29=0
lastgame30=0
#offset of last game run
offset=0
offset2=0
offset3=0
offset4=0
offset5=0
offset6=0
offset7=0
offset8=0
offset9=0
offset10=0
offset11=0
offset12=0
offset13=0
offset14=0
offset15=0
offset16=0
offset17=0
offset18=0
offset19=0
offset20=0
offset21=0
offset22=0
offset23=0
offset24=0
offset25=0
offset26=0
offset27=0
offset28=0
offset29=0
offset30=0
#amount of shadow on font
fontshadow=1
#tracball/spinner sensitivity
tracksens=2
#double click threshold
dblclick=4
#Type of mouse
#0=none
#1=standard
#2=tracball
#3=spinner
mousetype=1
#swap left and right mouse buttons
swapmouse=0
#Last custom list
lastcustom=0
lastcustom2=0
lastcustom3=0
lastcustom4=0
lastcustom5=0
lastcustom6=0
lastcustom7=0
lastcustom8=0
lastcustom9=0
lastcustom10=0
lastcustom11=0
lastcustom12=0
lastcustom13=0
lastcustom14=0
lastcustom15=0
lastcustom16=0
lastcustom17=0
lastcustom18=0
lastcustom19=0
lastcustom20=0
lastcustom21=0
lastcustom22=0
lastcustom23=0
lastcustom24=0
lastcustom25=0
lastcustom26=0
lastcustom27=0
lastcustom28=0
lastcustom29=0
lastcustom30=0
#NeoGeo custom list
customneo=8
#Vector custom list
customvector=8
#Hide warnings
hidewarns=1
#show run command
showcommand=0
#auto disable non-working games
autodisable=1
#auto rotate games, left/right
autorotate=0
#Screen shot to use when moving
altssonmove=0
#Screen shot to use when running
altssonrun=0
#Screen shot to use for info
altssoninfo=0
#pass screen centering info to MAME
easycenter=1
#show 'running dialog'
showrundialog=1
#Mouse Trails
mousetrails=0
#horizontal character count for arcade mode
arcade_h=105
#vertical line count for arcade mode
arcade_v=9
#horizontal character count for PAL mode
pal_h=105
pal_v=23
#horizontal character count for VGA scanline mode
scan_h=95
#vertical line count for VGA scanline mode
scan_v=11
#scale screen shots to fit display
scaletofit=1
#random number seed
seedcount=0
#X Mouse sensitivity
mousesensx=100
#Y Mouse sensitivity
mousesensy=100
#allow diagonals
diagonals=0
#flip screen in X
flipx=0
#flip screen in Y
flipy=0
#autorepeat count
autorepeat=5
#juke box screen saver delay
jukedelay=30
#Start 1+2=Escape
start12esc=1
#shift key
#1=Start1
#2=Start2
shiftkey=1
#Width of main window
widthhor=43
widthver=26
hreswidthhor=51
hreswidthver=51
#rotate backdrops
rotatepic=1
#games display
#0 = all, 1 = horizontal, 2 =rotated left or right, not rotated, 3 =disabled
disprot=1
disprot2=0
disprot3=0
disprot4=0
disprot5=0
disprot6=0
disprot7=0
disprot8=0
disprot9=0
disprot10=0
disprot11=0
disprot12=0
disprot13=0
disprot14=0
disprot15=0
disprot16=0
disprot17=0
disprot18=0
disprot19=0
disprot20=0
disprot21=0
disprot22=0
disprot23=0
disprot24=0
disprot25=0
disprot26=0
disprot27=0
disprot28=0
disprot29=0
disprot30=0
#ticks per second
ticks=60
#window colour schemes
wincolour0=8
wincolour1=9
wincolour2=0
wincolour3=1
#redirect output
redirectmame=1
#Indicates if shift keys are on or off (1=on,0=off)
shifton=0
#_shift + Player 1 button1 - Pause (P)
shift1=25
#_shift + Player 1 button2 - Config Menus (TAB)
shift2=15
#_shift + Player 1 button3 - OSD (Tilde)
shift3=41
#_shift + Player 2 button1 - Adjust Frame Skip (F9)
shift4=67
#_shift + Player 2 button2 - Speed throttling (F10)
shift5=68
#_shift + Player 2 button3 - Speed Display (F11)
shift6=87
#Buttons 1-3 on or off (0/1)
button1=1
button2=1
button3=1
#Move Up (arrow up)
kup=72
#Move Down (arrow down)
kdown=80
#Page Up (arrow left)
kleft=75
#Page Down (arrow right)
kright=77
#Change games orientation (left ctrl)
kp1butt1=29
#Change games shown (left alt)
kp1butt2=56
#Change orientation of ArcadeOS (Space)
kp1butt3=57
#Lock ArcadeOS (L)
klock=38
#Random Game (A)
kp2butt1=30
#Exit ArcadeOS (Esc)
kexit=1
#Control Menu (2)
kp2start=3
#Run Game (1)
kp1start=2
#Game Info (5)
kcoin1=6
#Close popup windows (Esc)
kclosewin=1
#Online help (Q)
kp2butt3=16
#Set Games' Custom List (S)
kp2butt2=31
#AOS Screen shot (F12)
ksshot=88
#Change emulators (6)
knxtemu=7
#Change custom list (7)
knxtclist=8
#Display Emu Menu (8)
kemulist=9
#Display Custom List Menu (9)
kcustlist=10
#Move Up pl2 (R)
k2up=19
#Move Down pl2 (F)
k2down=33
#Move Left pl2 (D)
k2left=32
#Move Right pl2 (G)
k2right=34
#Search Using CRCs
CRCSearch=0
#Automatically start last game played
#0=never,1=start if game was run,2=always
startlastgame=0
#Skip nag screens
skipnag=1
#Legacy List Generation
legacygen=0
#Overall Sound Interface volume (0-15)
soundvol=15
#Volume for startup sample (0-15)
startupvol=15
#Volume for shutdown sample (0-15)
shutdownvol=15
#Volume for window sample (0-15)
windowvol=15
#Volume for error sample (0-15)
errorvol=15
#Volume for saver sample (0-15)
savervol=15
#Volume for game sample (0-15)
gamevol=15
#Pitch for startup sample (0-100, 50 = normal)
startupfreq=50
#Pitch for shutdown sample (0-100, 50 = normal)
shutdownfreq=50
#Pitch for window sample (0-100, 50 = normal)
windowfreq=50
#Pitch for error sample (0-100, 50 = normal)
errorfreq=50
#Pitch for saver sample (0-100, 50 = normal)
saverfreq=50
#Pitch for game sample (0-100, 50 = normal)
gamefreq=50
#Drive which the 'File Menu' looks in
#0=A,1=B,2=C,3=D etc.
filedrive=0
#'Wrap Cursor' at start and end of menus
wrapcursor=0
#Screen shot position
#0=centre,1=top right,2=bottom right
#NOTE only takes effect if screen shot scaling is off
shotposition=0
#Using external arcade monitor TSR (such as MonARC)
extdriver=0
#Cocktail Mode (0=no , 1=yes) - moving up/down/left/right
#swaps AOS control between players and flips screen
cocktailmode=0
#Delay in seconds between 'flips' if cocktail mode is active
cocktaildelay=0
#State of gamed (launched or not) - internal use
runstate=0
#Which player has control over AOS 0=player 1,1=player 2 (internal use)
playercontrol=0
#Tint of screen shots
#0=normal,1=red,2=green,3=blue,4=grey
screentint=0
#Auto Capitalise display names of ROMS
#0=None,1=Short file names only,2=Long file Names only,3=All
#NOTE: This only affects ROM names without an NMS entry
capitalise=3
#Skip AOS's available disk space check when creating temp files
skipspacecheck=0
#Drive used for temp files (0='C',1='D',2='E' etc.)
tempdrive=0
#Custom lists contain copies of all games
#Useful when creating 'filter lists' (1=yes, 0=no)
#1 value for each possible emulator
customiscopy0=0
customiscopy1=0
customiscopy2=0
customiscopy3=0
customiscopy4=0
customiscopy5=0
customiscopy6=0
customiscopy7=0
customiscopy8=0
customiscopy9=0
customiscopy10=0
customiscopy11=0
customiscopy12=0
customiscopy13=0
customiscopy14=0
customiscopy15=0
customiscopy16=0
customiscopy17=0
customiscopy18=0
customiscopy19=0
customiscopy20=0
customiscopy21=0
customiscopy22=0
customiscopy23=0
customiscopy24=0
customiscopy25=0
customiscopy26=0
customiscopy27=0
customiscopy28=0
customiscopy29=0
#Filters are active (1=yes, 0=no)
filtersactive=1
#Filters (0-7 suffixes refer to custom list)
#Mininum number of players
minfiltplay0=1
minfiltplay1=1
minfiltplay2=1
minfiltplay3=1
minfiltplay4=1
minfiltplay5=1
minfiltplay6=1
minfiltplay7=1
#Maximum number of players
maxfiltplay0=8
maxfiltplay1=8
maxfiltplay2=8
maxfiltplay3=8
maxfiltplay4=8
maxfiltplay5=8
maxfiltplay6=8
maxfiltplay7=8
#Minimum year
minyear0=1970
minyear1=1970
minyear2=1970
minyear3=1970
minyear4=1970
minyear5=1970
minyear6=1970
minyear7=1970
#Maximum year
maxyear0=2010
maxyear1=2010
maxyear2=2010
maxyear3=2010
maxyear4=2010
maxyear5=2010
maxyear6=2010
maxyear7=2010
#Minimum vertical refresh frequency
minfreq0=30
minfreq1=30
minfreq2=30
minfreq3=30
minfreq4=30
minfreq5=30
minfreq6=30
minfreq7=30
#Maximum vertical refresh frequency
maxfreq0=75
maxfreq1=75
maxfreq2=75
maxfreq3=75
maxfreq4=75
maxfreq5=75
maxfreq6=75
maxfreq7=75
#Minimum number of coin slots
minslots0=1
minslots1=1
minslots2=1
minslots3=1
minslots4=1
minslots5=1
minslots6=1
minslots7=1
#Maximum number of coin slots
maxslots0=4
maxslots1=4
maxslots2=4
maxslots3=4
maxslots4=4
maxslots5=4
maxslots6=4
maxslots7=4
#Minimum X resolution
minxres0=0
minxres1=0
minxres2=0
minxres3=0
minxres4=0
minxres5=0
minxres6=0
minxres7=0
#Maximum X resolution
maxxres0=1280
maxxres1=1280
maxxres2=1280
maxxres3=1280
maxxres4=1280
maxxres5=1280
maxxres6=1280
maxxres7=1280
#Minimum Y resolution
minyres0=0
minyres1=0
minyres2=0
minyres3=0
minyres4=0
minyres5=0
minyres6=0
minyres7=0
#Maximum y resolution
maxyres0=1280
maxyres1=1280
maxyres2=1280
maxyres3=1280
maxyres4=1280
maxyres5=1280
maxyres6=1280
maxyres7=1280
#2 way joystick
joy2way0=1
joy2way1=1
joy2way2=1
joy2way3=1
joy2way4=1
joy2way5=1
joy2way6=1
joy2way7=1
#4 way joystick
joy4way0=1
joy4way1=1
joy4way2=1
joy4way3=1
joy4way4=1
joy4way5=1
joy4way6=1
joy4way7=1
#8 way joystick
joy8way0=1
joy8way1=1
joy8way2=1
joy8way3=1
joy8way4=1
joy8way5=1
joy8way6=1
joy8way7=1
#double 2 way joystick
dbljoy2way0=1
dbljoy2way1=1
dbljoy2way2=1
dbljoy2way3=1
dbljoy2way4=1
dbljoy2way5=1
dbljoy2way6=1
dbljoy2way7=1
#double 4 way joystick
dbljoy4way0=1
dbljoy4way1=1
dbljoy4way2=1
dbljoy4way3=1
dbljoy4way4=1
dbljoy4way5=1
dbljoy4way6=1
dbljoy4way7=1
#double 8 way joystick
dbljoy8way0=1
dbljoy8way1=1
dbljoy8way2=1
dbljoy8way3=1
dbljoy8way4=1
dbljoy8way5=1
dbljoy8way6=1
dbljoy8way7=1
#paddle
paddle0=1
paddle1=1
paddle2=1
paddle3=1
paddle4=1
paddle5=1
paddle6=1
paddle7=1
#dial
dial0=1
dial1=1
dial2=1
dial3=1
dial4=1
dial5=1
dial6=1
dial7=1
#trackball
trackball0=1
trackball1=1
trackball2=1
trackball3=1
trackball4=1
trackball5=1
trackball6=1
trackball7=1
#stick
stick0=1
stick1=1
stick2=1
stick3=1
stick4=1
stick5=1
stick6=1
stick7=1
#Minimum number of buttons
minbuttons0=0
minbuttons1=0
minbuttons2=0
minbuttons3=0
minbuttons4=0
minbuttons5=0
minbuttons6=0
minbuttons7=0
maxbuttons0=8
maxbuttons1=8
maxbuttons2=8
maxbuttons3=8
maxbuttons4=8
maxbuttons5=8
maxbuttons6=8
maxbuttons7=8
#horizontal games
horizontal0=1
horizontal1=1
horizontal2=1
horizontal3=1
horizontal4=1
horizontal5=1
horizontal6=1
horizontal7=1
#vertical games
vertical0=1
vertical1=1
vertical2=1
vertical3=1
vertical4=1
vertical5=1
vertical6=1
vertical7=1
#vector games
vector0=1
vector1=1
vector2=1
vector3=1
vector4=1
vector5=1
vector6=1
vector7=1
#raster games
raster0=1
raster1=1
raster2=1
raster3=1
raster4=1
raster5=1
raster6=1
raster7=1
#ROM folder
romfolder0=0
romfolder1=0
romfolder2=0
romfolder3=0
romfolder4=0
romfolder5=0
romfolder6=0
romfolder7=0
#displayed merged rom sets
mergedroms=1
mergedroms2=1
mergedroms3=1
mergedroms4=1
mergedroms5=1
mergedroms6=1
mergedroms7=1
mergedroms8=1
mergedroms9=1
mergedroms10=1
mergedroms11=1
mergedroms12=1
mergedroms13=1
mergedroms14=1
mergedroms15=1
mergedroms16=1
mergedroms17=1
mergedroms18=1
mergedroms19=1
mergedroms20=1
mergedroms21=1
mergedroms22=1
mergedroms23=1
mergedroms24=1
mergedroms25=1
mergedroms26=1
mergedroms27=1
mergedroms28=1
mergedroms29=1
mergedroms30=1
#LCD Screen Support (0=NO 1=YES)
lcdscreen=0
#LCD Screen COM Port (1-4) or LPT Port (5=LPT1, 6=LPT2)
lcdport=1
#LCD Serial Baud Rate (50,300,600,2400,4800,9600,19200,38400,57600,115200)
#or Parallel (Lines X 100) + Columns IE: 2x20 = (2 X 100) + 20 = 220
#             columns=64 for no autoformating desired.
#             lcdmode=0  if not using 44780 based LCD
lcdmode=9600
vettetek
« Reply #11 on: August 04, 2004, 10:15:04 pm »
heres the ADVMAME.RC file:
device_color_bgr15 yes
device_color_bgr16 yes
device_color_bgr24 yes
device_color_bgr32 yes
device_color_bgr8 yes
device_color_palette8 yes
device_color_yuy2 yes
device_joystick none
device_keyboard auto
device_mouse none
device_sound auto
device_svgaline_divideclock no
device_svgaline_skipboard 0
device_vbeline_16bit_clock_multiplier 1
device_vbeline_8bit_clock_multiplier 1
device_vbeline_clock_multiplier 1
device_vbeline_mode bigger
device_video auto
device_video_cursor auto
device_video_doublescan yes
device_video_fastchange no
device_video_interlace yes
device_video_output auto
device_video_overlaysize 1024
device_video_singlescan yes
dir_artwork artwork
dir_diff diff
dir_hi hi
dir_image image
dir_inp inp
dir_memcard memcard
dir_nvram nvram
dir_rom roms
dir_sample sample
dir_snap snap
dir_sta sta
display_adjust generate_yclock
display_antialias yes
display_artwork_backdrop yes
display_artwork_bezel no
display_artwork_crop yes
display_artwork_overlay yes
display_aspectx 4
display_aspecty 3
display_beam 1.0000
display_brightness 1.0000
display_buffer no
display_color auto
display_expand 1.0000
display_flicker 0.0000
display_flipx no
display_flipy no
display_frameskip auto
display_gamma 1.0000
display_intensity 1.0500
display_interlaceeffect none
display_magnify 2
display_mode auto
display_pausebrightness 1
display_resize mixed
display_resizeeffect auto
display_restore yes
display_rgbeffect none
display_rol no
display_ror no
display_scanlines no
display_skipcolumns auto
display_skiplines auto
display_translucency yes
display_vsync yes
include
input_hotkey yes
input_idleexit 0
input_map[coin1] auto
input_map[coin2] auto
input_map[coin3] auto
input_map[coin4] auto
input_map[event10] auto
input_map[event11] auto
input_map[event12] auto
input_map[event13] auto
input_map[event14] auto
input_map[event1] auto
input_map[event2] auto
input_map[event3] auto
input_map[event4] auto
input_map[event5] auto
input_map[event6] auto
input_map[event7] auto
input_map[event8] auto
input_map[event9] auto
input_map[p1_button10] auto
input_map[p1_button1] auto
input_map[p1_button2] auto
input_map[p1_button3] auto
input_map[p1_button4] auto
input_map[p1_button5] auto
input_map[p1_button6] auto
input_map[p1_button7] auto
input_map[p1_button8] auto
input_map[p1_button9] auto
input_map[p1_dial_down] auto
input_map[p1_dial_left] auto
input_map[p1_dial_right] auto
input_map[p1_dial_up] auto
input_map[p1_doubleleft_down] auto
input_map[p1_doubleleft_left] auto
input_map[p1_doubleleft_right] auto
input_map[p1_doubleleft_up] auto
input_map[p1_doubleright_down] auto
input_map[p1_doubleright_left] auto
input_map[p1_doubleright_right] auto
input_map[p1_doubleright_up] auto
input_map[p1_down] auto
input_map[p1_left] auto
input_map[p1_lightgun_down] auto
input_map[p1_lightgun_left] auto
input_map[p1_lightgun_right] auto
input_map[p1_lightgun_up] auto
input_map[p1_paddle_down] auto
input_map[p1_paddle_left] auto
input_map[p1_paddle_right] auto
input_map[p1_paddle_up] auto
input_map[p1_pedal1] auto
input_map[p1_pedal1_autorelease] auto
input_map[p1_pedal2] auto
input_map[p1_pedal2_autorelease] auto
input_map[p1_pedal] auto
input_map[p1_right] auto
input_map[p1_stick_backward] auto
input_map[p1_stick_down] auto
input_map[p1_stick_forward] auto
input_map[p1_stick_left] auto
input_map[p1_stick_right] auto
input_map[p1_stick_up] auto
input_map[p1_trackball_down] auto
input_map[p1_trackball_left] auto
input_map[p1_trackball_right] auto
input_map[p1_trackball_up] auto
input_map[p1_trakx] auto
input_map[p1_traky] auto
input_map[p1_up] auto
input_map[p1_x] auto
input_map[p1_y] auto
input_map[p1_z] auto
input_map[p2_button10] auto
input_map[p2_button1] auto
input_map[p2_button2] auto
input_map[p2_button3] auto
input_map[p2_button4] auto
input_map[p2_button5] auto
input_map[p2_button6] auto
input_map[p2_button7] auto
input_map[p2_button8] auto
input_map[p2_button9] auto
input_map[p2_dial_down] auto
input_map[p2_dial_left] auto
input_map[p2_dial_right] auto
input_map[p2_dial_up] auto
input_map[p2_doubleleft_down] auto
input_map[p2_doubleleft_left] auto
input_map[p2_doubleleft_right] auto
input_map[p2_doubleleft_up] auto
input_map[p2_doubleright_down] auto
input_map[p2_doubleright_left] auto
input_map[p2_doubleright_right] auto
input_map[p2_doubleright_up] auto
input_map[p2_down] auto
input_map[p2_left] auto
input_map[p2_lightgun_down] auto
input_map[p2_lightgun_left] auto
input_map[p2_lightgun_right] auto
input_map[p2_lightgun_up] auto
input_map[p2_paddle_down] auto
input_map[p2_paddle_left] auto
input_map[p2_paddle_right] auto
input_map[p2_paddle_up] auto
input_map[p2_pedal1] auto
input_map[p2_pedal1_autorelease] auto
input_map[p2_pedal2] auto
input_map[p2_pedal2_autorelease] auto
input_map[p2_pedal] auto
input_map[p2_right] auto
input_map[p2_stick_backward] auto
input_map[p2_stick_down] auto
input_map[p2_stick_forward] auto
input_map[p2_stick_left] auto
input_map[p2_stick_right] auto
input_map[p2_stick_up] auto
input_map[p2_trackball_down] auto
input_map[p2_trackball_left] auto
input_map[p2_trackball_right] auto
input_map[p2_trackball_up] auto
input_map[p2_trakx] auto
input_map[p2_traky] auto
input_map[p2_up] auto
input_map[p2_x] auto
input_map[p2_y] auto
input_map[p2_z] auto
input_map[p3_button10] auto
input_map[p3_button1] auto
input_map[p3_button2] auto
input_map[p3_button3] auto
input_map[p3_button4] auto
input_map[p3_button5] auto
input_map[p3_button6] auto
input_map[p3_button7] auto
input_map[p3_button8] auto
input_map[p3_button9] auto
input_map[p3_dial_down] auto
input_map[p3_dial_left] auto
input_map[p3_dial_right] auto
input_map[p3_dial_up] auto
input_map[p3_doubleleft_down] auto
input_map[p3_doubleleft_left] auto
input_map[p3_doubleleft_right] auto
input_map[p3_doubleleft_up] auto
input_map[p3_doubleright_down] auto
input_map[p3_doubleright_left] auto
input_map[p3_doubleright_right] auto
input_map[p3_doubleright_up] auto
input_map[p3_down] auto
input_map[p3_left] auto
input_map[p3_lightgun_down] auto
input_map[p3_lightgun_left] auto
input_map[p3_lightgun_right] auto
input_map[p3_lightgun_up] auto
input_map[p3_paddle_down] auto
input_map[p3_paddle_left] auto
input_map[p3_paddle_right] auto
input_map[p3_paddle_up] auto
input_map[p3_pedal1] auto
input_map[p3_pedal1_autorelease] auto
input_map[p3_pedal2] auto
input_map[p3_pedal2_autorelease] auto
input_map[p3_pedal] auto
input_map[p3_right] auto
input_map[p3_stick_backward] auto
input_map[p3_stick_down] auto
input_map[p3_stick_forward] auto
input_map[p3_stick_left] auto
input_map[p3_stick_right] auto
input_map[p3_stick_up] auto
input_map[p3_trackball_down] auto
input_map[p3_trackball_left] auto
input_map[p3_trackball_right] auto
input_map[p3_trackball_up] auto
input_map[p3_trakx] auto
input_map[p3_traky] auto
input_map[p3_up] auto
input_map[p3_x] auto
input_map[p3_y] auto
input_map[p3_z] auto
input_map[p4_button10] auto
input_map[p4_button1] auto
input_map[p4_button2] auto
input_map[p4_button3] auto
input_map[p4_button4] auto
input_map[p4_button5] auto
input_map[p4_button6] auto
input_map[p4_button7] auto
input_map[p4_button8] auto
input_map[p4_button9] auto
input_map[p4_dial_down] auto
input_map[p4_dial_left] auto
input_map[p4_dial_right] auto
input_map[p4_dial_up] auto
input_map[p4_doubleleft_down] auto
input_map[p4_doubleleft_left] auto
input_map[p4_doubleleft_right] auto
input_map[p4_doubleleft_up] auto
input_map[p4_doubleright_down] auto
input_map[p4_doubleright_left] auto
input_map[p4_doubleright_right] auto
input_map[p4_doubleright_up] auto
input_map[p4_down] auto
input_map[p4_left] auto
input_map[p4_lightgun_down] auto
input_map[p4_lightgun_left] auto
input_map[p4_lightgun_right] auto
input_map[p4_lightgun_up] auto
input_map[p4_paddle_down] auto
input_map[p4_paddle_left] auto
input_map[p4_paddle_right] auto
input_map[p4_paddle_up] auto
input_map[p4_pedal1] auto
input_map[p4_pedal1_autorelease] auto
input_map[p4_pedal2] auto
input_map[p4_pedal2_autorelease] auto
input_map[p4_pedal] auto
input_map[p4_right] auto
input_map[p4_stick_backward] auto
input_map[p4_stick_down] auto
input_map[p4_stick_forward] auto
input_map[p4_stick_left] auto
input_map[p4_stick_right] auto
input_map[p4_stick_up] auto
input_map[p4_trackball_down] auto
input_map[p4_trackball_left] auto
input_map[p4_trackball_right] auto
input_map[p4_trackball_up] auto
input_map[p4_trakx] auto
input_map[p4_traky] auto
input_map[p4_up] auto
input_map[p4_x] auto
input_map[p4_y] auto
input_map[p4_z] auto
input_map[safequit] auto
input_map[service] auto
input_map[service_coin1] auto
input_map[service_coin2] auto
input_map[service_coin3] auto
input_map[service_coin4] auto
input_map[start1] auto
input_map[start2] auto
input_map[start3] auto
input_map[start4] auto
input_map[tilt] auto
input_map[ui_add_cheat] auto
input_map[ui_cancel] auto
input_map[ui_cocktail] auto
input_map[ui_configure] auto
input_map[ui_delete_cheat] auto
input_map[ui_down] auto
input_map[ui_frameskip_dec] auto
input_map[ui_frameskip_inc] auto
input_map[ui_help] auto
input_map[ui_left] auto
input_map[ui_load_state] auto
input_map[ui_mode_next] auto
input_map[ui_mode_pred] auto
input_map[ui_on_screen_display] auto
input_map[ui_pan_down] auto
input_map[ui_pan_left] auto
input_map[ui_pan_right] auto
input_map[ui_pan_up] auto
input_map[ui_pause] auto
input_map[ui_record_start] auto
input_map[ui_record_stop] auto
input_map[ui_reset_machine] auto
input_map[ui_right] auto
input_map[ui_save_cheat] auto
input_map[ui_save_state] auto
input_map[ui_select] auto
input_map[ui_show_fps] auto
input_map[ui_show_gfx] auto
input_map[ui_show_profiler] auto
input_map[ui_snapshot] auto
input_map[ui_startup] auto
input_map[ui_throttle] auto
input_map[ui_toggle_cheat] auto
input_map[ui_toggle_debug] auto
input_map[ui_toggle_ui] auto
input_map[ui_turbo] auto
input_map[ui_up] auto
input_map[ui_watch_value] auto
input_steadykey no
misc_bios default
misc_cheat no
misc_cheatfile cheat.dat
misc_crash no
misc_difficulty none
misc_eventdebug no
misc_eventfile event.dat
misc_freeplay no
misc_hiscorefile hiscore.dat
misc_historyfile history.dat
misc_infofile mameinfo.dat
misc_internaldepth auto
misc_lang none
misc_languagefile english.lng
misc_mutedemo no
misc_quiet no
misc_safequit yes
misc_timetorun 0
record_sound yes
record_sound_time 15
record_video yes
record_video_interleave 2
record_video_time 15
script_coin1
script_coin2
script_coin3
script_coin4
script_emulation
script_event1
script_event10
script_event11
script_event12
script_event13
script_event14
script_event2
script_event3
script_event4
script_event5
script_event6
script_event7
script_event8
script_event9
script_led1 on(kdb, 0b1); wait(!event()); off(kdb, 0b1);
script_led2 on(kdb, 0b10); wait(!event()); off(kdb, 0b10);
script_led3
script_play
script_safequit
script_start1
script_start2
script_start3
script_start4
script_turbo while (event()) { toggle(kdb, 0b100); delay(100); } off(kdb, 0b100);
script_video wait(!event()); set(kdb, 0);
sound_latency 0.0500
sound_mode auto
sound_normalize yes
sound_resamplefilter yes
sound_samplerate 44100
sound_samples yes
sound_volume 0
sync_fps auto
sync_resample auto
sync_speed 1
sync_startuptime auto
sync_turbospeed 3
ui_font auto
ui_fontsize auto
ui_helpimage auto
ui_speedmark no
device_video_pclock 5-150
device_video_hclock 15.73
device_video_vclock 60
device_video_format 15730 0.8 0 0.075 0.125 0.919847 0.00763359 0.0114504 0.0610687
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« Reply #12 on: August 29, 2004, 12:40:29 pm »
Having same problem.
When I set filters active = no I can now see the games, but it appears the info is not working.
The games are listed by dos names, not the long names and the game info is blank.
That is why the filters were blocking view of any games because it appears the info is not there so the filters can't work.
Now, HOW TO GET THE INFO BACK!!!!!?????
vettetek
« Reply #13 on: August 29, 2004, 01:14:03 pm »
HUH,
Thats some info to me. I never had any info, or long file names...i thought thats how it was...now I guess I have another problem to sort out as well  :'(.
If I find something Ill let you know.
~V
