Author Topic: sensitive centering grommet? or something else...  (Read 1661 times)
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« on: August 22, 2002, 02:30:02 am »
I've got a WICO ball handle leaf joystick.  It's working great, but I noticed when playing some games
when I let go of the joystick  while in one position it would trigger the other direction.
For instance, holding it to the left and letting it go would trigger a 'right'.
I have since bought a perfect 360 kit  just to try it out and it  also works great but also has the same issue,
even maybe a little more sensitive.  It is very noticiable in games like Tetris and Pac-Man.
I'm wondering since it's a new joystick maybe it needs to be broken in a little?  If so any techniques?
Any  other ideas?
thanks
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
JustMichael
  • Mmmmm!! Cheesecake!!
Re:sensitive centering grommet? or something else...
« Reply #1 on: August 22, 2002, 11:18:11 am »
From what it sounds like, you are pushing a spring centering joystick all the way one way and wondering why it snaps back past center some.  This normally occurs.  You could try a heavier spring.  The heavier spring would also make it harder to move though.
If it has leaf switches you could try bending these away from the center a little bit more.
« Last Edit: August 22, 2002, 12:09:45 pm by JustMichael »
