Author Topic: How do you turn on tv when its mounted inside of a cabinet?  (Read 2331 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« on: August 01, 2004, 11:16:10 pm »
Im using a 27 inch tv as my monitor and just thought of a question, How do you turn it on and off once its bolted under a bezel and plexi glass?
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
  • Last login:Yesterday at 11:28:34 am
    • GroovyGameGear.com
Re:How do you turn on tv when its mounted inside of a cabinet?
« Reply #1 on: August 01, 2004, 11:39:04 pm »
Just drill a small, inconspicuous hole in the bezel right in front of the IR sensor and use the remote.
the3eyedblindman
« Reply #2 on: August 01, 2004, 11:41:44 pm »
is that how most people do it? and is there any other way besides puttin a hole in the bezel?
« Reply #3 on: August 01, 2004, 11:45:26 pm »
Other than selecting a TV that remembers it was on and on S-video when you pull the plug and plug it back in, no.
But if you use one of those, there's the powerstrip switch (even smart ones out there that the PC can control, IIRC).
« Last Edit: August 01, 2004, 11:46:48 pm by RandyT »
Bgnome
  • Last login:January 10, 2005, 04:05:16 pm
  • Who's da gnome?
« Reply #4 on: August 02, 2004, 12:04:07 am »
the TVs we have had in our family generally would turn on and be on the same channel when plugged in if they were on when unplugged.  i would try that first..
you could also hack the remote, mount the ir transmitter directly in front of the ir receiver on the tv, then wire a button to the cp.  or hack the tv power button in the same fashion with a button/switch/relay/capacitor, etc..
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #5 on: August 02, 2004, 01:25:14 am »
One other thing to try would be to actually hack the TV. Just wire a button onto the existing one. However, this would require opening the TV (read disclaimer below). It would be much neater but, again, a bit risky.
TVS ARE VERY HIGH POWER. OPEN AT OWN RISK. If you haven't read the warnings yet, do so now. TVs retain energy for a very long time after being unplugged.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #6 on: August 02, 2004, 05:35:37 pm »
Instead of connecting the TV power button to an arcade controls, I connected a cheap universal TV remote's power button to an arcade pushbutton.  Then I extended the IR emitter to the front of the TV, so when you press the button the remote turns the TV on.
Doug
  • Last login:December 18, 2005, 02:03:43 pm
« Reply #7 on: August 03, 2004, 01:50:07 pm »
I've been trying to tackle the same problem and here's the solution I came up with:
I've got a Sharp 25" T.V. with S-video that I plan to use.  It doesn't have the auto-power on after power loss.  However, if I can keep the power button down it will.  All I have to do is find the best way to keep the power button on the T.V. pressed down.
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #8 on: August 03, 2004, 01:55:03 pm »
Why not just go to Home Depot and buy a 15A or greater rocker switch and mount that either on the back or under the CP. Then you wire the tv directly to that or if you want to have an outlet you can wire it to a power strip or buy an outlet at Home depot while you are at it and wire the outlet to the switch. Then you can power on the whole cab with one flick of a switch.
I have a rocker switch on my cab, it works awesome.
old school gamer
  • Last login:December 22, 2006, 02:20:28 pm
  • Woodworking Genius, computer illiterate!
    • my homepage
« Reply #9 on: August 03, 2004, 03:49:07 pm »
I bought a 21' flat panel tv (daewoo brand) The coolest part is that it has a convex ?? (dome shaped) on/off button. Soooo all I did was mount the tv where I wanted , applied the monitor bezel ( I have a flat monitor bezel not a 3D one)and plexi tight up to that button and all I have to do is touch a spot on the plexi where that button is behind and the tv comes on. Very cool.... and the kids think its MAGIC!!
My tag line was inappropriate for a family oriented site. It has been changed by saint.<-- THATS better than anything I could have come up with!!!!!!! Thanks Saint!!!-
old school gamer
    • my homepage
« Reply #10 on: August 03, 2004, 03:52:58 pm »
If you look close at the picture you can see the on/off button on the tv. It is next to the audio/video inputs. The on/off button on this particular tv sticks out farther than any other button,or part, on the front of the tv. So I am able to turn it on and off by touching the plexi.
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #11 on: August 03, 2004, 06:37:53 pm »
I have a 27" zenith that works like that. I wedged a little wire connectey deal between the button and the TV's case, and it's worked fine for about a year now. Wired a standard push button to the motherboard's power pins, and I'm using a SmartStrip to power the TV (and other components) on when the PC powers up.
