Author Topic: Control panel viewer available  (Read 2203 times)
cpviewer
  • Last login:April 24, 2009, 03:12:12 pm
    • CPViewer
« on: July 31, 2004, 07:30:15 pm »
I have finally finished version 1 (now at 1.2) of my CPViewer application. It
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
Re:Control panel viewer available
« Reply #1 on: August 01, 2004, 07:18:44 pm »
Looks pretty good, but when I try to get the "pacman" layout, it doesn't work. It seems that Puckman is the parent to pacman and that is what's in the controls.ini. Maybe you could try finding the parent rom's info and displaying that if the child rom doesn't exist?
cpviewer
    • CPViewer
« Reply #2 on: August 01, 2004, 08:48:59 pm »
I thought about that but am not sure how "Authentic" it would be. Some of the wording or controls could have changed or may be different. I'll see what others think. Maybe an option to enable or disable?
Thanks for the feedback,
John
EndTwist
  • Arg.
« Reply #3 on: August 01, 2004, 09:24:36 pm »
While working with it, I noticed a couple of problems:
1. When useing the configuration wizard, hitting back at certain points causes the program to error out.
2. When loading a file with rotated text, it doesn't always (never?) load correctly.
3. It would be nice to show games that can be played in cocktail mode the definitions of the controls on each side
4. You should be able to have multiple copies of each label
5. You should be able to individually flip labels.
cpviewer
    • CPViewer
« Reply #4 on: August 01, 2004, 09:29:00 pm »
Explain what you mean with number 2 in a little more detail if you could.
Thanks,
John
cpviewer
    • CPViewer
« Reply #5 on: August 01, 2004, 09:54:54 pm »
I was able to reproduce this in one spot. I'll get on it.
Thanks,
John
EndTwist
  • Arg.
« Reply #6 on: August 01, 2004, 11:08:39 pm »
Well, if I make the text vertical, save, exit, reopen it, and open my layout the text isn't rotated vertically to the left, but the normal horizontal.
cpviewer
    • CPViewer
« Reply #7 on: August 19, 2004, 07:42:11 pm »
Can you explain to me why you may want to do this?
Thanks,
John
mahuti
« Reply #8 on: August 20, 2004, 11:36:49 am »
I have some pinball buttons on the side that are mapped to the same button as some on the main panel.
Some people with the franken panels probably have something like this as well.
Buddabing
« Reply #9 on: August 21, 2004, 10:35:45 pm »
It would be nice to have the program run as a batch process to create control panel images. That way it would mesh well with the work I'm doing on displaying control panel images within MAME when pause is pressed.
Please read the wiki!
jcrouse
  • Last login:January 09, 2010, 05:53:51 pm
    • CPViewer
« Reply #10 on: August 22, 2004, 12:46:04 am »
Excellent Idea! I'll look into this.
Thanks,
John
jcrouse
    • CPViewer
CPViewer 2.0 in NOW available
« Reply #11 on: August 22, 2004, 12:27:17 pm »
A new version of my CPViewer (control panel viewer) has been posted with quite a few additions. You can check it out here: http://home.comcast.net/~cpviewer
Enjoy,
John
cdbrown
  • Last login:October 16, 2017, 09:52:03 pm
  • Bowowow
« Reply #12 on: August 23, 2004, 01:44:01 am »
Just about to install this and check it out.  You might want to change the .net hyperlink to http://msdn.microsoft.com/netframework/downloads/updates/default.aspx as the link in the installer is no longer valid.
Cheers
-cdbrown
« Reply #13 on: August 24, 2004, 04:25:53 am »
That's because xp service pack 2 includes the .net framework, which is a good thing as people always forget to download it. :)
