Author Topic: Just a few Lazarus questions  (Read 1839 times)
thelevin8r
  • Last login:June 09, 2006, 03:25:20 am
« on: August 21, 2002, 03:36:31 pm »
Some of these questions may be better if a made several separate posts, but I
  • Last login:Today at 01:32:52 pm
Re:Just a few Lazarus questions
« Reply #1 on: August 21, 2002, 04:10:07 pm »
Firstly the artwork....  It must be unzipped.  The folder names must be "snap","cabinets","marquees", and "flyers"  You point to the path as you did though.. just "c:\mame\" and it will automatically search for those folder names above inside it.
The next and previous page buttons (z and x by default) move between lists.  The 3 key is the experimental random select key.
Your list responsiveness problems can be one of two things....
#1 You have some artwork that is HUGE (not likely since your haing artwork probs)
#2 You need to tweak your scroll rates in your lazarus.ini Lower numbers isn't always better in this case... you need to find a good balance.  Remember that up and down move one at a time rather slowly for accuracy and left and right move a page at a time, very quickly for long lists.
The problem with a log is the only way to do it is to trap errors.  If I go to that much trouble then I might as well write intelligent error messages.  The wrappers do have very basic logs though.... If you look in a dir that contains one you'll find a log.txt showing the last command it passed.
