Author Topic: Physical power from PC  (Read 766 times)
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« on: July 28, 2004, 11:16:09 am »
I'm planning to take power from my ps to light my coin returns.  How should I physically get the power from my Y-connector to the coin return?
I was thinking of drilling a hole in my pc case to run the cable to my coin returns (not sure if this is such a good idea).
What's the best way to do this?
SirPeale
  • Green Mountain Man
Re:Physical power from PC
« Reply #1 on: July 28, 2004, 11:31:22 am »
Pop out a drive cover.  Open the case.  Drill a hole in the side/front.  There's a lot of ways to do it.  It doesn't matter which way you do it, just do what makes you happy.
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« Reply #2 on: July 28, 2004, 11:54:56 am »
You could also do it through an empty PCI slot in the back.  Better yet, take that slot cover (each PCI slot should have one -- you know, the ones that you remove when you actually put in a card) and drill a hole in that and then run the power connector out of the back.  That's probably the cleanest...   I wouldn't go drilling holes into a case if you don't have to.
