Author Topic: Mechanized Attack Optics  (Read 1054 times)
MasTequila
  • Last login:November 13, 2004, 12:07:53 pm
  • I'm a llama! Here me roar!
    • GameTruth
« on: July 27, 2004, 05:43:17 pm »
I picked up a Mechanized Attack game and I was wondering if there is any place I could get a replacement board because one of the guns is bad.  I did a search of the forum and got nothin.  Thanks in advance.
~Mas
APFelon
  • Last login:July 04, 2024, 08:51:53 pm
Re:Mechanized Attack Optics
« Reply #1 on: July 27, 2004, 07:47:01 pm »
Hm... You might be able to repair the board yourself. A common problem with light guns is that the diode's legs can break off from the opto PCB. Check that before you drop what could be a wad of cash in a new opto board... Check for broken wires, too. If I remember correctly, the mechanized attack game has the guns mounted to the panel... Violent movements could have broken a wire.
Good luck!
APf
MasTequila
    • GameTruth
« Reply #2 on: July 27, 2004, 09:37:20 pm »
Ok thanks.  If I was to get a new one where would I get it from?  Are they all just standard or do different optical guns have different boards? Thanks in advance.
~Mas
APFelon
« Reply #3 on: July 27, 2004, 10:05:12 pm »
I'd check HAPPS. I don't think I have ever been in a mech attack, but we had one on location. I'm not sure if it uses a HAPPS style opto board or not... Sorry.
APf
MasTequila
    • GameTruth
« Reply #4 on: July 27, 2004, 10:59:51 pm »
Thanks APFelon.  Does anyone know if the optics inside are happs or not? Thanks in advance
~Mas
