Author Topic: drill before routing?  (Read 1544 times)
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« on: July 25, 2004, 12:54:34 am »
While I'm waiting for my 1/16" 3-wing slot cutter to arrive, I'd like to drill all the holes and cut out the piece for the tb on my cp.
Is there any reason why I should wait to drill/cut until after I have routed for the tmolding?
SirPeale
  • Green Mountain Man
Re:drill before routing?
« Reply #1 on: July 25, 2004, 01:19:59 pm »
I don't think so.  You're just going to be cutting the slot around it, after all.
Scoobie
« Reply #2 on: July 25, 2004, 03:17:41 pm »
Sounds good to me!  Off to drilling I go...
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: July 25, 2004, 04:05:37 pm »
if you route out a big hole close to the edge you might have problems keeping your router level when you are doing the slot for the t-molding.
Drilling would be fine, but make sure you have enough space around that tb.
Scoobie
« Reply #4 on: July 26, 2004, 12:38:35 am »
Well, I drilled all the holes and cut out the tb.  Once the router bit arrives, I'll let you know what happens.   :)
