Author Topic: help need fast answer to chd problem  (Read 1797 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: July 22, 2004, 06:08:56 pm »
ok i have a windows 98 machine that runs arcadeos upon booting into windows. now it shows up with all the games including trhe chd game but when i go to run them it says ***.chd not found. now this is running advmame .83 dos version. i tried to run the windows version but got a error. this machine im trying to fix for a friend and dont know why they wont work in dos. the chd games that is. they will however work with mame32 .83 so it isnt a version conflict. chds have been properly changed over to the new format. they are in the correct folder for each game within the rom folder. also i was told that they look for it in the rom folder itself too so i tried that with no avail. does anybody know the answer to this problem thanx for the info
SirPeale
  • Green Mountain Man
Re:help need fast answer to chd problem
« Reply #1 on: July 23, 2004, 12:28:54 am »
Can you run the CHD gamse from the command prompt?
GMZombie
« Reply #2 on: July 23, 2004, 02:34:44 am »
no i cannot. just from within windows in mame32
SirPeale
« Reply #3 on: July 23, 2004, 08:51:07 am »
Then it's not configured right.  You must have missed something somwhere.  What is the exact error you get when trying to run the CHD game @ the command prompt?
GMZombie
« Reply #4 on: July 23, 2004, 01:31:22 pm »
it says after trying to run for example kinst.chd cannot be found. and it is there its the newe version of it and it is also just in the roms folder as welll as in its on subfolder.
SirPeale
« Reply #5 on: July 23, 2004, 03:32:32 pm »
It gives you this exact error?
Code: [Select]
kinst.chd    NOT FOUND
ERROR: required files are missing, the game cannot be run.
So, to reiterate:
1) your setup is *something* like this:
C:\MAME
     mame.exe
C:\MAME\ROMS
     kinst.zip
C:\MAME\ROMS\KINST
     kinst.chd
2) Your ROMpath in your mame.cfg is set to your ROMs folder(s)
Double check all of this.  I'm still convinced you missed something somewhere.
Edit: are you using the DOS version, or the Windows version?  There *is* a difference, a big one.
GMZombie
« Reply #6 on: August 14, 2004, 05:04:53 am »
dos version
KHAN
  • Last login:March 28, 2005, 05:14:27 pm
« Reply #7 on: August 14, 2004, 09:49:10 am »
Use clrmame to fix this problem.......
chd is not taking a place in the rom......
this site is based on frontend discussion....
if u still missing  take a look here....
www.retroroms.official-website.net
BLUE BIRDS FLY WITH BLUE BIRDS
