Author Topic: Electrohome G07 - Brightness Adj.  (Read 4196 times)
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
« on: July 21, 2004, 06:49:49 pm »
I have an Electrohome G07 and was curious if this monitor has a brightness and contrast adjustment ?
The label on the side of the monitor reads the following:
Chassis : G07CB0
Product : 38-G07-904-I0
This monitor was recently capped, and also had a new flyback installed. Overall, the picture is great, it just seems a little darker than I used to.
Thank you in advance,
Mike
Ken Layton
  • Guru
  • Technician
Re:Electrohome G07 - Brightness Adj.
« Reply #1 on: July 21, 2004, 07:15:33 pm »
There is no contrast adjustment on Electrohome monitors. There is no "brightness" control per se, but you use the "screen" control on the flyback as a brightness control. Typically after installing a capkit (regardless of monitor make or model) you usually have to reset the the brightness level.
General Zod
  • Banned
« Reply #2 on: July 21, 2004, 07:34:13 pm »
Thank you Ken. I was able to remedy that using the advice you gave me.
Again, many thanks to you.  :)
Michael
