Author Topic: MAMEWAH and screenshots.  (Read 1249 times)
APFelon
  • Last login:July 04, 2024, 08:51:53 pm
« on: July 20, 2004, 02:49:41 pm »
I updated to the latest MAMEWAH last week and I like the new features. The only thing that is baffling me is why the ingame screenshots are no longer showing up in the upper right corner.
I have the artwork directory set up correctly. When the screensaver kicks in, it shows the ingame pics without a hitch.
I am using the default layout.
Can someone give me a clue?
APf
Minwah
    • MAMEWAH
Re:MAMEWAH and screenshots.
« Reply #1 on: July 20, 2004, 04:27:59 pm »
You've got me there...
Doesn't really make sense as your screensaver shots show up, but just to make sure the image decoder is properly installed could you do Start > Run > regsvr32 paintx.dll
Let me know if it makes any difference...
APFelon
« Reply #2 on: July 21, 2004, 09:47:10 am »
Thanks for the tip Minwah. but that wasn't the problem... and I am not quite sure what WAS the problem. I am not 100% sure how MAMEWAH works, but when I changed the layout I was fine. But the thing is... when I unzipped the layouts (about a year ago) they ended up in the mamewah/layouts/layouts folder.
Since MAMEWAH worked, I never questioned the folder placement (aesthetics of the FE wasn't / isn't a priority so I never tinkered with it).
So, MAMEWAH was loading SOMETHING, I'm just not sure what. Whatever it was loading didn't accomodate the screenshots.
APf
Minwah
    • MAMEWAH
« Reply #3 on: July 21, 2004, 01:47:57 pm »
Well that sheds a little light at least...
MAMEWAH will not have been loading *any* layout, rather using what I call the 'built-in Classic 640x480'.  But still, that layout should work in exactly the same way as the 'real' Classic 640x480...I just tried it and it seems to work fine for me, so I can't really explain it  ???  At least you found a solution!
