Author Topic: leg levelers  (Read 1123 times)
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
leg levelers
« on: July 20, 2004, 08:32:36 am »
i was looking at leg levelers and the weight and cost of each and wasn't sure which one i needed to put on the bottom of my cab. if i have 4 levelers and each can hold 200 lbs each, can 4 levelers support 800 lbs? i was looking at happs levelers that are under PC Arcade-Accessories (by the way, how do you put a link here to happs products? do you just put a link to the price page?). i'll be building the cab from LuSiD's plans.
Ken Layton
  • Guru
  • Technician
Re:leg levelers
« Reply #1 on: July 20, 2004, 09:53:26 am »
What are you building that's 800 pounds in weight?!  :o A pool table?
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
Re:leg levelers
« Reply #2 on: July 20, 2004, 10:00:53 am »
don't forget there's occasions you may need to rock/wiggle/walk  the cab on one or two levelers to get it into or out of a particular spot (tilting it back onto castors or a hand truck also places it on the back 2 levelers), so the whole weight of the cab would be on  one or 2 levelers for a few seconds..:-)
200 lb ratings wouldn't be out of line imho....
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
Nefesis
Re:leg levelers
« Reply #3 on: July 20, 2004, 11:12:53 am »
hmmm... a pool table... good idea  :D . hah. and if i could pull it off then i'm (insert inventor of pool table here) ________   ;) . no, i'm just not sure how much this cab is going to weigh. so the 200 lbs it is!
