Author Topic: PS2 Analog stick "hacking"  (Read 2245 times)
Zathras
  • Last login:June 06, 2011, 01:06:02 am
  • Yeah.
« on: July 16, 2004, 10:34:58 am »
I would like to make a custom amplitude/frequency controller.
The trick is you have to have an analog stick (or some modification to have one accessable).
Has anyone made a PS2 arcade joystick with analog capability?
« Last Edit: July 16, 2004, 11:18:16 am by Zathras »
Space Warped by Someone
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:PS2 Analog stick "hacking"
« Reply #1 on: July 17, 2004, 03:29:57 pm »
You have a couple options, but the outlook is still not good.
You can hack a digital 8-way to the potentiometers of an PS2 analog stick, but then it won't really be analog (would similate full pressure in any of 8 directions).  If the game requires precise movement (half way pressure for example) then this won't work.
You can try to hack a happ 49-way stick (found on ebay for cheap at times) using the circuit described in the Game Consoles section of this site.  As far as I know nobody has attempted or gotten it to work yet.  I tried to wire it up on a breadboard but used a ps2 3rd party stick that wasn't 5v (was 3.3v at the analog sticks)...need to try again one of these days...
You could buy a happ arcade analog stick and hack to the ps2 analog, but the happs analog stick is $180.
Thats pretty much all your options.
Floyd10
« Reply #2 on: July 23, 2004, 02:35:30 pm »
Thats if its for a cab. He didnt mention that it was for one
