Author Topic: Questions about using a PAL TV..  (Read 1654 times)
durak
  • Last login:September 03, 2010, 06:49:14 am
« on: July 16, 2004, 08:52:12 am »
Hi!
I haven't yet decided what kind of display I will use, but here's few questions I need answered if I end up with a TV.
1. If I buy a TV with scart compatible with RGB, does it automatically also mean it is compatible with 60Hz? Or does it even need to be compatible with 60Hz?
2. As it's quite impossible to know if a TV has RGB scart or not when buying used, can you give me advice what brands generally have/have not rgb scarts? I'd probably end up buying some TV from 90's.
3. Just so I'm not assuming anything wrong, if I connect the TV to arcadevga with a proper cable, _everything_ will run properly?
4.Off-topic question, if I end up buying a PC monitor, will it need to be a high quality one? Or will some used multisync 21" from mid nineties do the job?
Thanks for anyone who might reply.  ;)
« Last Edit: July 16, 2004, 08:53:55 am by durak »
giantgonzolez
  • Last login:July 17, 2004, 06:21:37 pm
Re:Questions about using a PAL TV..
« Reply #1 on: July 17, 2004, 06:26:23 pm »
Scart RGB will obviously give you the most realistic "arcade look" and "arcade feel", but it would probably be more complex to hook up too.
I'll ask your question at this other forum since those guys are really knowledgable about everything RGB.
http://nfg.2y.net/forum/index.php?s=3216481723ff260b68f81e0540621966&act=SF&f=5
Here's the question I asked, hopefully it will get some replies.
http://nfg.2y.net/forum/index.php?showtopic=792
« Last Edit: July 17, 2004, 06:30:27 pm by giantgonzolez »
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #2 on: July 18, 2004, 11:02:45 am »
Hi!
If the TV is rated PAL it is not required to accept 60Hz signals. It is my experience that most SCART sockets accept 60Hz RGB fine though despite being rated as a PAL set.
Most 25inch sets from the last 10 years have had SCART sockets. However, having a SCART socket does not automatically means that it will accept RGB. The only mandatory signal through SCART is audio and composite video. Major brands should be fine though: Sony, Philips, JVC and Grundig. Avoid off-brand stuff like ProVision, AudioSonic, Panasonic, etc.
If _everything_ means horizontal oriented 4:3 15kHz standard resolution games, then yes. Vertical oriented games can often not be displayed on a horizontal screen without scaling.
Also, a TV cannot display 25kHz medium resolution games without interlace or scaling. The amount of medium resolution games supported by MAME is expected to increase of the coming years. We are now seeing Sega System 24, Sega Model X and Atari Vegas hardware emulated which require medium resolution monitors.
In case you are wondering: scaling is bad because it degrades picture quality and authenticity. Interlace is bad because it makes the screen flicker and is obviously not authentic either. Interlace puts a lot of strain on the eyes as well. Not recommended.
Most likely, yes. You don't need very high resolution monitors to run arcade games. If you get something that has at least 500 - 600 lines you will be fine.
« Last Edit: July 18, 2004, 11:03:32 am by b3atmania »
durak
« Reply #3 on: July 19, 2004, 07:23:34 am »
Thanks for both of you!  :)
