Author Topic: Is one of my trackball boards damaged?  (Read 1165 times)
sfetaz
  • Last login:March 11, 2008, 12:58:28 pm
  • DDR4LIFE
    • Home of DDR Machine Rentals and The Madison Square Garden DDR Championships!
« on: July 16, 2004, 04:47:29 am »
I have a Betson 3" Trackball.  I am trying to make an adapter that will interface it with PS/2.  I have bought 2 different brand new ball mice so far.  The end result each time is that the Vertical Y axis on the mouse board goes bad.  Originally tested the Vertical was fine, but after connecting the 6 pin molex I made up to the board, Horizontal works fine but vertical does not.  Then when I take the optic wheel that came with the individual mouse to test the board itself, horizontal works fine and vertical does not.  Before everything was fine.  This has happened on 2 different mice.  How can I check the vertical board in the trackball to verify if it is doing something to the mice boards that is damaging the vertical?
« Last Edit: July 16, 2004, 04:51:39 am by sfetaz »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re:Is one of my trackball boards damaged?
« Reply #1 on: July 16, 2004, 09:12:46 am »
You've probably got a power connection wrong, sending power to the wrong pin and causing it not to work.
NO MORE!!
sfetaz
  • DDR4LIFE
« Reply #2 on: July 16, 2004, 02:34:33 pm »
Found out my trackball is fine, its my mouse hacks.  Can anyone reccommend a good ball mouse to use?
NoOne=NBA=
« Reply #3 on: July 16, 2004, 03:27:11 pm »
Just buy one of the USB Mouse Hacks from Oscar, and save yourself the trouble.
The mouse hack is $9.00 + shipping.
If you want a cable that will just plugs in on both ends, it will run you another $8.00.
The mouse hack has pin connectors where the emitter/detector would normally be, and you can just hook right up to them.
