Author Topic: ArcadeOS help  (Read 1749 times)
itismejs
  • Last login:February 29, 2012, 05:25:43 pm
ArcadeOS help
« on: July 12, 2004, 08:20:13 pm »
I am trying to setup arcadeOS. I have read other posts but they havent answered all my questions. I have all the games I like to play and they dont take up much space. (they consist of a handful of  MAME and a lot of NES games)I would like someone to create a simple boot floppy(that loads arcadeOS and nesicle from the CD rom drive.(if possible tell the system to save highscores/save data to the C drive)
itismejs
Re:ArcadeOS help
« Reply #1 on: July 13, 2004, 09:48:03 am »
I have set everything up but the roms folder. in the config file it asks for the locations of the roms (its in a folder called roms on the C: drive) so put in in C:\roms this still doesnt work! I have tried various other ways and they still say rom cant be found?!?!?!?!?!?!?!
SirPeale
  • Green Mountain Man
Re:ArcadeOS help
« Reply #2 on: July 13, 2004, 09:52:01 am »
Put them in the ROMs folder in your Mame directory.
Unless you've changed that in your mame.(ini/cfg)
What version of Mame are you using?
itismejs
Re:ArcadeOS help
« Reply #3 on: July 13, 2004, 10:12:21 am »
I am running th newest version. I moved the roms to C:\mame\roms
CthulhuLuke
  • Last login:May 22, 2025, 01:03:42 am
  • old school
    • CthulhuLuke's Arcade Parodius
Re:ArcadeOS help
« Reply #4 on: July 13, 2004, 10:18:22 am »
Hey Peale, I'm trying to help out itsmejs, but I'm also having problems with ArcadeOS.  I'll state first of all I'm running a Windows XP Pro setup, but I can get ArcadeOS running fine by changing compatibility to Windows 95 in the config of the .exe.  So I located c:\emulators\mame   I have my roms in c:\emulators\mame\roms  I'm testing this with Mame v0.66 windows, it runs the roms from command prompt fine.  the beginning of my arcadeos.cfg looks like this:
#path for mame
mamepath=c:\emulators\mame\
#executable for mame
mameexe=mame.exe
#executable used to get game and clone list
infoexe=mame.exe
#configuration file used by mame executable
config=mame.cfg
   I still cannot get any of the roms to display in ArcadeOS, any suggestions?  I've been trying to double check everything, and I'm still seeing nothing.
edit: ok I turned filters off, and now I see all of the folders in my /mame/ directory along with the 2 roms I have in the /roms/ folder, any suggestions?
« Last Edit: July 13, 2004, 10:24:10 am by CthulhuLuke »
SirPeale
Re:ArcadeOS help
« Reply #5 on: July 13, 2004, 12:01:19 pm »
change the config to 'mame.ini' and make 'mame.ini' read-only.  Try that.
Unfortunately arcadeos is mainly set up for older versions of Mame.  Carlos Santillan is trying to fix that.
itismejs
Re:ArcadeOS help
« Reply #6 on: July 13, 2004, 02:26:13 pm »
I got an older version of mame. It havea list of games but when I try and play em it just closes w/ no message. And it even says it cant find ne thing but it does ne way. Which version of mame does arcadeOS work with best.
SirPeale
Re:ArcadeOS help
« Reply #7 on: July 13, 2004, 04:47:41 pm »
What version, specifically?
 .36 might be your best bet.
