Author Topic: Wirring diagram needed for turbo sit down cab steering wheel  (Read 1087 times)
rob1234
  • Last login:September 23, 2022, 07:40:58 am
I need the wirring diagram for a turbo sit down cab steering wheel. Anyone out there install an oscar mouse hack on one? If so I could use some info on how to do it and maybe some pics. THANKS!
lostboy4480
  • Last login:December 22, 2025, 10:26:26 pm
Re:Wirring diagram needed for turbo sit down cab steering wheel
« Reply #1 on: July 13, 2004, 04:37:47 am »
What part do you need a diagram for ? I have a sit down turbo cab in my garage..  Will see if I can take pics of the wiring of the wheel tomorrow, if I get in from work at a reasonable time
Cabinets
NBA Jam
Golden Tee 2005
PGA Tour Golf Team Challenge
Tekken 5: Dark Resurrection
Generic Taito (Project)
rob1234
« Reply #2 on: July 13, 2004, 10:24:19 am »
i have the wires all connected right now, I need to know what each wire is for so I can cut them and hook up an oscar mouse hack for mame use.
NoOne=NBA=
« Reply #3 on: July 13, 2004, 12:19:43 pm »
It would be alot easier to just replace the optic board with one of Oscar's.
That's what I did with mine.
I'm not sure that the original can be used; and, if it can, it's probably more trouble than it's worth.
That seems to be the norm with original optic boards.
They are much more complicated than the replacements from Oscar, and are designed to interface to the original boards, rather than a mouse hack.
