Author Topic: Incredible table tennis game!  (Read 1012 times)
Gradius
  • Last login:February 04, 2008, 03:10:49 pm
« on: July 11, 2004, 01:43:32 pm »
WOW! This game is brilliant. The simulation is perfect and it's so addictive! Give it a try: http://www.grassgames.com/ttpro/index.html
pointdablame
Re:Incredible table tennis game!
« Reply #1 on: July 11, 2004, 03:53:52 pm »
The game is pretty damn good.  A bit difficult to play with my laptop's touch pad though.  Someone should try it out with a trackball in their cab and report back if its any good.
first off your and idiot
Minwah
    • MAMEWAH
« Reply #2 on: July 11, 2004, 04:40:17 pm »
It's pretty tricky in general, but very good...
Seems to have a few bugs tho.  If you are particularly bad at the tutorial (the spin one is pretty tricky), then the game crashes...I also found if I do the tutorial again having already completed it, it crashes also.
Also I found that sometimes when you hold a button and move the mouse to aim the shot, the bat doesn't move (usually it rotates so you can see when you are aiming) - that one is pretty major.
I bet it would work pretty well with a trackball...
