Author Topic: Will photopaper stick/smudge to Plexi?  (Read 1283 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: July 11, 2004, 11:33:07 am »
I see alot of people put clear plexi on their CPs, so I was thinking, there's no point then in having it professionally printed on vinyl...
My question: Has anyone tried just printing it with an inkjet on photo-paper and then laying the clear plexi on top? If I do this, will the ink/paper end up sticking to the plexi, and bleeding or anything like that? (In other words, is it a bad idea?)
NO MORE!!
rsoandrew
  • Last login:February 24, 2018, 09:02:10 am
  • Worldwide travelling Mame Machine
    • Andrew's Arcade
Re:Will photopaper stick/smudge to Plexi?
« Reply #1 on: July 11, 2004, 12:38:44 pm »
Stick - yes
Smudge -no
I printed out some pictures and put them in cheap frames with plexi instead of glass. I never had any problems until I tried to update the pictures. The pictures tended to stick to the plastic and a couple of the pictures were damaged. The plastic cleaned up fine.
spystyle
« Reply #2 on: July 11, 2004, 12:44:41 pm »
I printed my CPO on self-adhesive paper and covered it with lexan, I also used the overlay as a cutting template (no measuring required)
If you want to make your prints "spill resistant" you could spray them with a automotive clear coat.
It saves a bundle on printing if you are building on a shoe string budget. ($1 per square foot vs Kinko's $10 per square foot)
Not the route to take if you are a maticulous perfectionist though, I've been flamed about this method because it leaves "seems"
Dig it?
Craig
« Last Edit: December 09, 2006, 11:44:37 am by spystyle »
