Author Topic: Drilling through Formica laminate  (Read 9307 times)
Jakedakat
  • Last login:August 18, 2005, 08:40:06 pm
« on: July 05, 2004, 07:07:57 am »
I am getting ready to mount my contols finally and had a couple questions. I am not the greatest carpenter ;) which is why I took a shortcut and bought a Slik Stik Quad blank. I am gonna be using carriage bolts to mount the joysticks, what I was wondering is should I drill from the top of the panel or the bottom? The panel is covered with a Formica laminate. Also any special kind of drill bit I should use? Any advice would be great thanks!
Rob
SNAAAKE
  • -Banned-
Re:Drilling through Formica laminate
« Reply #1 on: July 05, 2004, 09:08:10 am »
You drill from the TOP !
« Last Edit: July 05, 2004, 10:32:26 am by SNAAAKE »
JAMMA Guy
  • Last login:June 18, 2004, 01:14:07 am
  • PCB's Are Better!
« Reply #2 on: July 05, 2004, 09:38:52 am »
You can drill from the bottom as long as you sandwich the laminate between another piece of wood ... this way is won't leave a rough hole when the drill bit breaks on through the laminate.
Hoagie_one
  • Um....whats a cabinet
« Reply #3 on: July 05, 2004, 09:42:48 am »
sandwich, and clamp it
SideShow Rob
« Reply #4 on: July 05, 2004, 10:42:35 am »
Drill from the top.
Use a 1/8" (3mm) wood drill bit for a pilot hole first, and then use the correct size wood drill bit for the hole proper.
Take your time and go slow, and you should get excellent results.
Jakedakat
« Reply #5 on: July 05, 2004, 01:51:37 pm »
Great thanks for the tips, gonna give it a try tommorow!
Rob
spriggy
  • Last login:October 07, 2025, 01:33:26 am
« Reply #6 on: July 05, 2004, 11:33:51 pm »
Also, try putting some decent masking tape over the backside of the area you are going to drill.  Can help stop chipping/splintering the edges of the laminate whilst drilling...that is if that side is laminated!!
Game On!
« Last Edit: July 05, 2004, 11:35:10 pm by spriggy »
"Once a Knight, always a Knight.   Twice a night.. and your doing alright!!" ::)
Mr. Dude
  • Last login:March 03, 2019, 05:12:50 am
  • Hi...
« Reply #7 on: July 06, 2004, 04:15:09 pm »
I would definately sandwich the board with two peices of wood and then drill through.  This will give you nice clean holes without cracking the formica.
« Last Edit: July 06, 2004, 04:16:10 pm by Mr. Dude »
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
« Reply #8 on: July 06, 2004, 06:13:43 pm »
I did my original static CP using black formica laminate before I converted it to modular.
I drilled it from the top using a spade bit - it seemed to leave a cleaner hole than the hole saw.  However, it also heated the drill bit a lot and dulled it rather quickly.  The hole saw I had had trouble getting through the laminate layer, so I used the spade for most of the holes.
High speed is a definite plus.  I had access to a drill press that ran about 3600 RPMs and it went through the laminate like a knife through butter (but also REALLY heated the bit).  The handful  I had to drill with a regular drill (around 1200 RPM) seemed to take forever.
« Last Edit: July 06, 2004, 06:14:08 pm by Doc- »
