Author Topic: LEDs and Resitstors  (Read 1083 times)
whiteraven
  • Last login:February 17, 2012, 04:56:58 pm
LEDs and Resitstors
« on: July 04, 2004, 04:40:25 am »
I got a mixed bag of "12 Volt LED CAR BULBS" from www.superbrightleds.com and I want to hook them up to my computers power supply.  It was mentioned that resistors were needed and this is what I need help with.
What type of resistor do I need?
here are the specs for the leds:
Single LED Wedge Base Bulbs
Voltage: 12~14 VDC
Current: 20~25 mA
Size: 8mm x 24mm
I have some of the 4 bulb leds aswell but I think that the specs would be similar to the single LED bulbs mentioned above.
Please not that I live in Ireland and we don't have Radio Shack over here.  So once I know what type of resistor I need it may be a misson to find somewhere that has them for sale.
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re:LEDs and Resitstors
« Reply #1 on: July 04, 2004, 10:45:37 am »
Generally it's true you need to use current limiting resistors with LED's, but those already have the resistors made into them for connection to a 12v supply.
They were made for automotive applications, which also happens to be 12v.  So you should be able to hook them right up/plug 'em in.
D
whiteraven
« Reply #2 on: July 04, 2004, 02:32:21 pm »
Excellent!  Thanks, it was something that was wondering about.
