Author Topic: MAME memory / roms / disk usage question  (Read 1097 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: July 03, 2004, 08:46:22 pm »
Need an OS / application guy here...when MAME loads a rom, is it loading it into memory and running it from memory?  I ask because I am setting up dos mame with multiple drives and want to know if there is any disk IO used to access the roms during gameplay.  Thanks!
  • Last login:February 11, 2026, 07:46:44 pm
Re:MAME memory / roms / disk usage question
« Reply #1 on: July 04, 2004, 05:32:24 am »
Yes, it sure does.  Cfg files and harddisc images are read from the harddrive though.
Btw because of this and the poor way that dos handles memory (it pretty much doesn't) and the lack of "true" support for newer hardware  you shouldn't be running dos if your system is farily modern.  Bascially if you have more than 128 megs of ram and your harddrives are larger than 8 gig and your processor is faster than 300 mhz you should be running windows.
That isn't an opinion btw... those are the benchmarks at which dos can safely handle your resources in an efficient manner.  Any larger than that and it just gets sloppy and basically the extra power isn't utilized properly.
gregor7777
  • Last login:March 14, 2022, 04:07:00 pm
  • I'm your huckleberry. Say When...
« Reply #2 on: July 04, 2004, 01:54:29 pm »
I wonder about my 500 Celly system w/128mb RAM. If I run win98 with mamewah as a shell if I'll be able to play some of the early streetfighter titles and vampire titles? maybe add some more RAM?
