Author Topic: Horzonital Width Coil needed  (Read 1223 times)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« on: June 30, 2004, 11:06:56 am »
I've got a Sharp Image SI-327 monitor that needs a width coil.
Any clues?
the manual just lists it as a 610-020.
(Also the monitor has a hula problem, (has built in switcher) any hints on which caps (I'm guessing ac leakage into the dc) to try first?
Later,
dabone
Ken Layton
  • Guru
  • Technician
Re:Horzonital Width Coil needed
« Reply #1 on: June 30, 2004, 11:08:53 am »
Contact both the tech support and the parts dept at the manufacturer, www.sharpimage.net
dabone
  • Time to work...
« Reply #2 on: June 30, 2004, 12:20:04 pm »
Dang it...
Closed for inventory till the 6th.
Thppptth.
Later,
dabone
Ken Layton
  • Guru
  • Technician
« Reply #3 on: June 30, 2004, 05:48:29 pm »
Try also www.casinotech.com as they repair most brands of arcade and gaming monitors. I know some Cherry Master machines and video poker used Sharp Image monitors. Chances are they could help too.
