Author Topic: Tool to "turn" trackball axis ???  (Read 2013 times)
FloLob
  • Last login:June 08, 2004, 07:35:10 am
« on: June 25, 2004, 02:32:37 pm »
I just installed the ultimarc trackball into my metal
controlpanel. I had to turn the trackball 45 degrees for the installation, because of lacking space. And now ..... guess what ... the mousecursor moves diagonally.
Is there a tool or something that "turns" the mouseaxis 45 degrees back to normal ?
(Sorry for my bad english. But I haven't learned in school how to talk about trackballs.)
_Iz-
  • Last login:January 15, 2026, 06:23:28 pm
  • Time to coin up!
Re:Tool to "turn" trackball axis ???
« Reply #1 on: June 25, 2004, 02:41:57 pm »
Nope, if you'd just rotated it 90
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
« Reply #2 on: June 25, 2004, 03:13:46 pm »
It is an epidemic!  There was just this post on the same subject last week...
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=20482;start=msg165518#msg165518
It is easy to install it at an angle by mistake, actually looks like you did this on purpose (not realizing the results though  :( )
:) Rotate or die! :)
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #3 on: June 25, 2004, 05:34:32 pm »
Sorry Man, I don't know of any hardware or software to fix that.   If you turned it by 90 or 180 degrees, then you'd have some options, but not here.
vputz
  • Last login:August 23, 2010, 08:16:05 am
  • I'm a llobter!
« Reply #4 on: June 25, 2004, 07:45:29 pm »
Agreed with the above.  The trackball has two sensors, one vertical, one horizontal, so there's no hardware way to fix the problem.  Software...maybe.  You'd have to use a clever driver to mux the two inputs together and rotate.  It could be done, but you'd need a very clever mouse driver.
Some like that do exist, though I'm not sure they'd be compatible with your trackball.  May be worth looking at.
-->VPutz
FloLob
« Reply #5 on: June 26, 2004, 09:21:35 am »
Thx for your replies.
I will get a new metalpanel and try it again.
How could one be that stupid .....  :-\
Minwah
    • MAMEWAH
« Reply #6 on: June 26, 2004, 10:35:05 am »
I just replied to this at MAMEWorld...but:
I think there is a setting somewhere in Accessability Options for this...basically for people who have trouble moving the mouse exactly forward/backward etc.  I don't know if will allow the amount of adjustment you need, but definately have a look before you make a new panel...
