Author Topic: Garryb Cab - WIP photo - need help.  (Read 4544 times)
big_garryb
  • Last login:June 09, 2006, 08:08:12 am
« on: June 25, 2004, 01:56:55 pm »
Hi everyone - thanks for reading.
i need your help, encouragement and advise - ive hit snag with the cab.
i decided to cover the sideart with plexi - was a good idea in my head. being a numptie i didnt price the plexi - it will cost
oh dear - not rain again......Scottish weather is crap, oh well - at least Mame can keep me company.
whammoed
  • Last login:Yesterday at 04:03:09 pm
  • Crack don't smoke itself
    • NiceMite
Re:Garryb Cab - WIP photo - need help.
« Reply #1 on: June 25, 2004, 02:21:48 pm »
Where are you pricing the lexan...If it is at a home improvement place, try a local plastic supplier instead.  I find the prices much more reasonable.
There are also edge trimmers for t-molding:
http://www.tapeease.com/t-molding_tools.htm
but they are probably too expensive to justify just one use...perhaps some careful trimming with a razor would do the trick?  Try it on a test piece first of course.
hope this helps
Witchboard
  • Last login:January 05, 2022, 09:09:24 pm
    • Oklahoma Coin-Operated Collectors
« Reply #2 on: June 25, 2004, 02:27:07 pm »
Damn, that does suck.  Hmmm..
Depending on what tools you have available to you, you could rip some 2mm strips on a table saw or something and glue a border a couple inches thick around the outside edge.  Fill, sand then paint.  Then use the inside for side art.  It would look like a recessed area where the art would be.
See if smaller t-molding is available and route a new slot if you're screws aren't in the way.
Maybe not use t-molding?  Use another type of molding that you glue or iron on?
I guess you could always do #1 and remake the sides of your cab.
Good luck in whatever you do.  Man... that does suck.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #3 on: June 25, 2004, 02:28:42 pm »
Fill in the routed slot, and route again?
AGGIEZ
  • Last login:January 30, 2017, 05:59:50 pm
« Reply #4 on: June 25, 2004, 07:02:27 pm »
I wonder if you could use some self leveling gel to cover it? That might be a pretty cool alternative but you'd be breaking new ground. All you'd have to do is lay the cab on it's side and fill.
http://www.goldenpaints.com/technicaldata/selfgel.php
mozzer
  • Last login:March 02, 2019, 10:38:25 pm
  • How Soon Is Now?
« Reply #5 on: June 25, 2004, 07:05:44 pm »
That's not a bad idea Aggiez.
It says it dries to a clear flexible film. How durable is it? Does it scratch easy?
whammoed
    • NiceMite
« Reply #6 on: June 25, 2004, 08:43:16 pm »
Is that the stuff you see on restaurant tables sometimes?  If so, and if not for that matter, really interesting idea.  If it is that stuff it seems really durable.
whammoed
    • NiceMite
« Reply #7 on: June 25, 2004, 08:47:23 pm »
This is the stuff i'm thinking of:
http://www.shopmaninc.com/kk121.html
AmericanDemon
  • The Reason the short bus was invented... 100% Slacker Guaranteed, 4:20 yet?
  • Last login:Yesterday at 01:01:31 am
  • Still an AmericanDemon
« Reply #8 on: June 25, 2004, 09:43:01 pm »
If you hit it hard enough it'll chip.  Sharp points will gouge it.  Its hard to get just right.  If you are wanting a rolled over look, it will take you some time to get it perfect.
Refilling the routed slot is a better idea.  Have a second go at it.
AGGIEZ
« Reply #9 on: June 26, 2004, 03:21:29 am »
Yeh. I'm not sure about the durability, but if they put that stuff on restaurant tables, it has to be pretty damn durable! Most anything will gouge with a sharp point scratching it and I don't really see how "self leveling" would be difficult. Anyways, just an idea. Let us know how you fix the problem...
pcdoctor
  • Last login:July 21, 2014, 06:44:02 am
  • I'm a Girl Gamer!
« Reply #10 on: June 26, 2004, 05:08:32 am »
Is that a 25" or 27" monitor?
Also is that a UAII cab or plans you used yourself?
Very nice!
« Last Edit: June 26, 2004, 05:09:48 am by pcdoctor »
boyowilkins
« Reply #11 on: June 26, 2004, 04:57:39 pm »
Cab looks real good m8  ;D
Filling in the groove and starting again sounds the best idea to my simple mind....
« Last Edit: June 26, 2004, 04:58:02 pm by boyowilkins »
big_garryb
« Reply #12 on: June 27, 2004, 10:56:38 am »
sorry guys - been offline since i started the post....... thanks for the feedback.
filling and re-routing wouldnt work because the t-mold is 2mm wider then the wood anyway it goes....... although i suppose 1mm each side would be better than 2mm at one side............ might pop down to b&q tomorrow after work fr a look for some 2mm panelling.
failing that i might fill and reroute and just accept the 1mm each side - a couple of people want the cab off me already - so i could give it away as a gift then do a new one!!!!!!!!  ::)
It is a 25" screen......... and sort of just winged it with the plans as i went along - it came out great since no real thought went into the process............ well a bit.
at least my next cab will be better as i will know the dodgy bits!!
simplygriff
  • Last login:January 10, 2008, 10:05:05 am
    • simplygriff.com
« Reply #13 on: June 29, 2004, 12:08:33 pm »
Nice looking Cab!
Do they make off center t-Molding?  I could have sworn they had it at www.t-molding.com
Maybe I'm crazy. ??? :o ::) :o ???
www.simplygriff.com
art : videogames : transformers : life
Live, but Under Heavy Construction
big_garryb
« Reply #14 on: June 29, 2004, 04:21:00 pm »
never thought of that griff............ i will check that out!!
thanks
garry
CCM
« Reply #15 on: June 30, 2004, 09:18:41 am »
yep, there is off-set t-molding...  check it out and see if it's the right size for you...
http://www.t-molding.com/cart/customer/product.php?productid=11&cat=4&page=1
Matt, GoC
  • Last login:August 18, 2005, 02:00:07 am
  • Must... stop... itching!!!
    • GameOn!
« Reply #16 on: July 10, 2004, 09:40:46 pm »
I used acrylic plastic on my CP and plan to use it on the sides of my cab to protect my side art, as you planned to do.  I forget the brand name of the plastic but I'll get it if you want.  It is quite cheap and versitile.   I used a stronger, more expensive version for my CP, and was able to drill several dozen holes without hardly a crack (nothing visible).  For a more general use, the cheaper version should suffice.  I think it was called Plastikote but not exactly sure.  I paid about $30USD for a sheet of the tough stuff (the lighter-dudy plastic is about half the cost), and it was enough for two tries of a CP at 14x40 inches, with a little to spare.  I'd try that before filling in your sides with goo.  Hope that helps!
